Odd problem with source folder definition [message #183344] |
Fri, 22 October 2004 11:24  |
Originally posted by: sstephens.renewdata.com
Hey folks. I have a problem specifying source files that are below the
top level project folder - most work fine, but this case isn't.
Here's some specifics for my current situation:
My java application is built with two sibling projects
- common
- myapp
myapp includes common as a project, and myapp has the following dir
structure:
-.- myapp
|-.- src
| |-.- main
| | |-.- com.mycompany.package
| |-.- test
| | |-.- com.mycompany.testpackage
The problem is, I've got a test class extending a class from the
StrutsTestCase jar (com.mycompany.app.cactus.LoginLogoutTest extends
CactusStrutsTestCase) in which the package statement for the java class
gives me a red underline error in eclipse:
"The declared package does not match the expected package
src.test.com.mycompany.app.cactus"
Other pertinent facts:
1) In the project properties source tab, the folders chosen are
myapp/src/main and myapp/src/test.
2) Other tests in the same package that extend ServletTestCase (in the
cactus.jar) do not show the error on the package statement - so I'd
imagine its not simply because of specifying deeper folders in the source
tab.
Any ideas on what the problem could be? I've tried defining the struts
test case jar and the cactus jar in User libraries or as individual jars
(in the libraries tab of the properties dialog) - no change.
I've exhausted everything I can think of to solve it, so feel free to
throw you're ideas out there. If you need more info, I'll be glad to
supply it.
Sean
Re: Odd problem with source folder definition [message #183355 is a reply to message #183344] |
Fri, 22 October 2004 12:06  |
As an update, moving the offending test down one more package to
com.mycompany.app.cactus.actions gets rid of the error.
Although its still a mystery to me why there was an error when the class
was in the com.mycompany.app.cactus package.
- Sean
FUDForum. Page generated in 0.03184 seconds
