Eclipse launching external editor [message #183161] |
Tue, 05 December 2006 19:28  |
Originally posted by: jcleland.jamescleland.com
I've searched for an answer to this question, but came up empty. I apologize
if it's already been answered somewhere else.
Whenever I double-click an item in the problem window and sometimes when I
select an error or warning icon from the editor, Eclipse tries to open the
respective file using an external editor. I don't want this to happen, but
I'm clueless as to how I can prohibit this behavior. It may not be relevant,
but this is within a java project and I'm using 3.2, although the same
behavior existed in 3.1.
James
Re: Eclipse launching external editor [message #183285 is a reply to message #183226] |
Wed, 06 December 2006 15:00  |
They are java files, your suggestion worked fine, thanks!
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:el6klc$mdi$1@utils.eclipse.org...
> jcleland wrote:
>> apologize if it's already been answered somewhere else.
>> I select an error or warning icon from the editor, Eclipse tries to open
>> the respective file using an external editor. I don't want this to
>> happen, but I'm clueless as to how I can prohibit this behavior. It may
>> not be relevant, but this is within a java project and I'm using 3.2,
>> although the same behavior existed in 3.1.
> What kind of file(s) (what are the extensions)?
> Eclipse associates extensions with various editors; one of the editor
> choices is "System" editor (whatever editor your OS has associated with
> that kind of file). If you ever opened a particular file with something
> other than the default editor (by right-click and choosing Open With...),
> Eclipse will remember that and continue to use that editor. This is what
> may be happening in your case. The remedy is to right-click the
> problematic file and choose Open With > Default Editor. Then Eclipse will
> remember that choice.
> Hope this helps,
> Eric
FUDForum. Page generated in 0.07492 seconds
