Home » Language IDEs » ServerTools (WTP) » roblem with eclipse/jboss using lomboz framework
roblem with eclipse/jboss using lomboz framework [message #17251] Thu, 05 February 2004 11:51 Go to next message
Originally posted by: guillespie.free.fr
Hi everybody
I am about to learn J2ee development with ide Eclipse using Lomboz framework
and jboss application server.
I developped yet a minimal ejb that I wish to deploy and test with a minimal
test client application.
the problem is when I'am running test application under j2ee a exception
occurs: here is the code;
log4j:ERROR Failed to create directory structure: /log
log4j:ERROR setFile(null,false) call failed.
java.io.FileNotFoundException: /log/boot.log (No such file or directory)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:272)
etc ...
does someone know how to help me about this fact ?
perhaps problem in jboss configuration but I am in pain to locate it.
thanx a lot for helping.
Re: roblem with eclipse/jboss using lomboz framework [message #17713 is a reply to message #17251] Tue, 10 February 2004 05:29 Go to previous message
Originally posted by: christophe.ney.objectweb.org
Hi Ali,
May I suggest you use the lomboz@objectweb.org for such question
thanks,
christophe
ali k. wrote:
> Hi everybody
> etc ...
Previous Topic:[JOB] Seeking Sr. Eclipse Developer
Next Topic:Internal error when browsing Webdav target site
Current Time: Sat Nov 08 20:37:36 EST 2025
Powered by FUDForum. Page generated in 0.02744 seconds
