Home » Modeling » GMF (Graphical Modeling Framework) » Rotating the Image
Rotating the Image [message #182984] Tue, 15 April 2008 00:43
I have an image inside the node edit part (Rectangle) which i want to
rotate.
The image is the rendered image attached to the node edit part as image
descriptor.
The container (node) edit part implements IRotatableEditPart and the
command which is written to rotate the editpart, rotates the node edit
part but not the
image inside.
Does any one know how to rotate the image alond with it's node edit part?
Previous Topic:children elements in an element with diagram partitioning feature
Next Topic:Figures in a plugin and XYLayout
Current Time: Fri Oct 31 10:58:41 EDT 2025
Powered by FUDForum. Page generated in 0.03183 seconds
