Home » Language IDEs » Java Development Tools (JDT) » doing recursive AST rewrites
doing recursive AST rewrites [message #182558] Thu, 14 October 2004 14:09 Go to next message
Originally posted by: emerson.cse.ogi.edu
Howdy,
I've been working with the ASTRewrite in a few contexts, but have always
had this minor problem where I can't do two rewrites that occur, nested,
in the same expression. For example, I have the following expression:
var1 = var2
and I would like to see it changed to:
setVar1(getVar2());
So essentially I traverse the tree, replacing Assignments with
MethodReferences and some SimpleNames with MethodReferences. Since the
Assignment is expressed first, the I first add the change:
var1 = var2 --> setVar1(var2)
then, when I come upon the SimpleName var2, I add the change:
var2 --> getVar2()
So far, so good. But when I actually do the rewrite, I only get:
setVar1(var2)
I imagine the problem here is that once the 1st rule is executed, the
2nd rule is no longer valid or applicable because var2 no longer exists
in the AST (just a semantically identical SimpleName).
To get around this, I can traverse the AST twice; once to make the
"getter" replacements, and then once more to make the "setter"
replacements. Sad, that.
Alternatively, I might be able to reorder the AST changes such that
SimpleNames are replaced before Assignments. Anyone know if this would
work, or has a better idea?
Thanks!
-e
Re: doing recursive AST rewrites [message #182686 is a reply to message #182558] Fri, 15 October 2004 10:52 Go to previous messageGo to next message
Are you diectly modifying the AST or are you using the describing
ASTRewrite?
If it's the first, please file a bug against jdt.core.
If it's the describing Rewrite:
When you did
what did you fill in as 'var2'? The correct thing is insert there a
'move target' of 'var2'.
Emerson Murphy-Hill wrote:
> Howdy,
> var1 = var2
> setVar1(getVar2());
> var2 --> getVar2()
> setVar1(var2)
> Thanks!
> -e
Re: doing recursive AST rewrites [message #182875 is a reply to message #182686] Mon, 18 October 2004 11:43 Go to previous message
> ASTRewrite?
The latter.
> When you did
Yes, I believe I'm doing that. For the replacement of the assignment:
protected void replaceFieldAssignmentWithSetter(Assignment node) {
SimpleName lhsName = getLeftHandSideName(node);
int flags = getFlags(lhsName.getIdentifier());
MethodInvocation setter = getSetter(lhsName);
setter.arguments().add(
getRewrite().createMoveTarget(node.getRightHandSide()));
getRewrite().replace(node,setter,getTextEditGroup());
And for the target:
protected void replaceFieldAccessorWithMethodCall(SimpleName node){
MethodInvocation getter = getGetter(node);
getRewrite().replace(node,getter,getTextEditGroup());
Any other suggestions?
Thanks!
e
>> Howdy,
>> always had this minor problem where I can't do two rewrites that
>> occur, nested, in the same expression. For example, I have the
>> var1 = var2
>> setVar1(getVar2());
>> the Assignment is expressed first, the I first add the change:
>> var2 --> getVar2()
>> setVar1(var2)
>> exists in the AST (just a semantically identical SimpleName).
>> would work, or has a better idea?
>> Thanks!
>> -e
Previous Topic:key binding for next compile error
Next Topic:extracting new ASTNodes out of an ASTRewrite
Current Time: Fri Oct 17 06:34:03 EDT 2025
Powered by FUDForum. Page generated in 0.05009 seconds
