Build multiple makefiles [message #182496] |
Thu, 18 January 2007 13:57  |
Originally posted by: icarus_31.yahoo.com
I have already a Linux project in hands that was done using makefiles. One
makefile that calls other makefiles with a makefile.inc. Here is the
"tree" of my project
ROOT
|-- PRJ1: makefile, c code
|-- PRJ2: makefile, c code
|-- PRJn: makefile, c code
|-- makefile
|-- makefile.inc
I succeeded to import the project inside Eclipse.
I have cygwin and GNUARM installed on Windows XP. Yes I want to compile
that code in XP. Probably later I will do it in Linux as well.
Now, I want to compile everything using the existent makefile. How can I
do that?
Re: Build multiple makefiles [message #182595 is a reply to message #182543] |
Sat, 20 January 2007 07:06  |
Originally posted by: asdf.dd.dd
> Now, my problem is more about the makefile. I have an error when searching
> for a variable. Anyway, I do not think this problem should be mention in
> that newsgroup
You are probably right, are you sure that it can compile from the command
line ?
Otherwise it could be something about wrong default directory ?
tpt
FUDForum. Page generated in 0.07049 seconds
