Home » Language IDEs » ServerTools (WTP) » java.library.path
java.library.path [message #182374] Wed, 08 November 2006 10:47 Go to next message
In my servlet I need to load a dll. Using WTP, how do I specify the
java.library.path for the loading?
Zohar.
Re: java.library.path [message #182435 is a reply to message #182374] Thu, 09 November 2006 22:08 Go to previous messageGo to next message
Originally posted by: mohsen.siahe.com
WTP creates a new running configuration for Tomcat or other servers you are
using. add -Djava.library.path to VM arguments on run window (arguments
tab).
"Zohar" <david_fire4@hotmail.com> wrote in message
news:eisu9d$lcj$1@utils.eclipse.org...
> Hello,
> Zohar.
Re: java.library.path [message #182520 is a reply to message #182435] Sun, 12 November 2006 01:57 Go to previous messageGo to next message
thanks.
Where is the best place to put the dlls and the loading classes?
"Mohsen Saboorian" <mohsen@siahe.com> wrote in message
news:ej0qm9$hh0$1@utils.eclipse.org...
> are using. add -Djava.library.path to VM arguments on run window
> (arguments tab).
>> Hello,
>> Thanks,
>> Zohar.
Re: java.library.path [message #182561 is a reply to message #182520] Sun, 12 November 2006 21:45 Go to previous message
On a web app, you MUST put your JAR files on web-module/WEB-INF/lib, and the
classes on web-module/WEB-INF/classes. Applications usually put the needed
resources on web-module/WEB-INF/classes (puting it on src folder will
automaically copy it each time I think).
news:ej6gou$pbd$1@utils.eclipse.org...
> thanks.
>> (arguments tab).
>>> Hello,
>>> Thanks,
>>> Zohar.
Previous Topic:Software engineering for J2EE
Next Topic:Only one web-app can run on server
Current Time: Sat Nov 08 00:46:00 EST 2025
Powered by FUDForum. Page generated in 0.04010 seconds
