C++ search for methods [message #182232] |
Wed, 29 November 2006 21:15  |
Originally posted by: pedz.easesoftware.com
I must be doing something terribly wrong.
I took an existing project and moved it into Eclipse running the C++
add on (I think it is call CDT). I downloaded everything maybe a month
ago but never played with it until tonight so I have relatively recent
levels of Eclipse and CDT.
My true objective is to find where the ctor for LockedPort is called.
I searched for LockedPort::LockedPort in all the different ways and
places I can find and it never finds much of anything. I've tried
finding the open method of LockedPort and it can't find it.
It can find the declarations or definitions (I don't know which --
maybe both) but it can not find references.
The project compiles. I've hit "Refresh". I've tried closing the
project and reopening it. Nothing.
Aside from waking up this morning, where did I go wrong?
Perry Smith ( pedz@easesoftware.com )
Ease Software, Inc. ( http://www.easesoftware.com )
Low cost SATA Disk Systems for IBMs p5, pSeries, and RS/6000 AIX systems
Re: C++ search for methods [message #182661 is a reply to message #182571] |
Fri, 01 December 2006 17:55   |
> I don't use CDT, but in JDT you can right-click on a method name
> (either in the code editor or in one of the views that show a
> structured view of code) and choose References... from the pop-up menu.
> That will search in various scopes for references to that element
> (method, class, field, etc.)
> I would think that CDT works the same or similarly. Have you gone
> through the CDT tutorials? They probably demonstrate how to navigate
> code easily.
> Hope this helps,
> Eric
I tried that too but it does not find anything. I'm wondering if I got
the indexer confused somehow.
Re: C++ search for methods [message #182668 is a reply to message #182261] |
Fri, 01 December 2006 17:57  |
I can't find a similar view in CDT that I can switch to.
On 2006-11-29 23:32:17 -0600, Eric Woodruff <eric.services@ideoform.org> said:
> Java has the notion of a Call Hierarchy however I'm not sure if the CDT
> has this feature.
> But a google search seems to suggest it does:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.cdt-cor e/org.eclipse.cdt.refactoring/?cvsroot=Tools_Project
(file)
> plugin.xml 1.8 3 months mschorn Call Hierarchy: Actions
> to open the call hierarchy, navigation of nodes
> Perry Smith wrote:
>> That is not what I'm looking for. Thanks. Those two things are pretty
>> cool though.
>> I want to find all the places where the ctor is used. Or, if the ctor
>> is a hard example, find all the places where are particular method is
>> called from. I don't want to search for just "open" because I have many
>> classes that have an open method. I want to be able to find just the
>> places where LockedPort::open is called. (But it is not going to be
>> written in the C++ text as LockedPort::open. Instead, it is going to be
>> lp.open(); where lp is of type LockedPort.
>> I have no idea of CDT has that much C++ understanding but I was hoping
>> it did.
>> On 2006-11-29 21:41:39 -0600, Eric Woodruff <eric.services@ideoform.org>
>> said:
>>> To do something like that in the JDT (Java Tools) and CDT I do Ctrl +
>>> Shift + T for the Open Type action. Then the Outline View will show you
>>> the constructor (you can customize the order that it shows elements in
>>> that view) or you can press Ctrl + O to see the outline in a tool-tip
>>> like thing (which might be called an "infopop"?).
>>> Open Type can be found in the Navigate menu.
>>>> I took an existing project and moved it into Eclipse running the C++ add
>>>> on (I think it is call CDT). I downloaded everything maybe a month ago
>>>> My true objective is to find where the ctor for LockedPort is called. I
>>>> searched for LockedPort::LockedPort in all the different ways and places
>>>> I can find and it never finds much of anything. I've tried finding the
>>>> It can find the declarations or definitions (I don't know which -- maybe
FUDForum. Page generated in 0.07701 seconds
