Home » Newcomers » Newcomers » 3.1 vs. 3.2?
3.1 vs. 3.2? [message #182175] Wed, 29 November 2006 12:48 Go to next message
Originally posted by: rjtescher.netscape.net
Yesterday I downloaded and installed 3.2 into a separate
directory from 3.1.
3.2 appears to be working fine, is there any reason to
keep the 3.1 directory around?
I have been [ab]using
Eclipse for over a year, but still consider myself a
"newcomer".
As I keep my the workspace in a separate directory from
either version, is there anything from my old directory
I should copy over?
Re: 3.1 vs. 3.2? [message #182183 is a reply to message #182175] Wed, 29 November 2006 13:28 Go to previous messageGo to next message
> directory from 3.1.
> "newcomer".
> I should copy over?
The only think I would recommend is to Export... => Preferences and save
all into a file that you keep before removing 3.1, as I find that I
remember having some capability that I no longer have, and having a set
of preferences to browse through that show how I liked things when
things worked right.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: 3.1 vs. 3.2? [message #182556 is a reply to message #182183] Fri, 01 December 2006 13:13 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Randy D. Smith wrote:
>> directory from 3.1.
>> keep the 3.1 directory around? I have been [ab]using
>> "newcomer".
>> I should copy over?
You may also want to take note of any thrid-party plugins that you might
have installed into 3.1, go find out if they have 3.2-compatible
versions of them and install in your 3.2
Hope this helps,
Eric
Re: 3.1 vs. 3.2? [message #183443 is a reply to message #182556] Thu, 07 December 2006 22:21 Go to previous message
Thanks!
Previous Topic:Web Design View
Next Topic:Getting extensions
Current Time: Mon Jul 21 23:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.11046 seconds
