Home » Language IDEs » C / C++ IDE (CDT) » CPU doesn't support the debugger
CPU doesn't support the debugger [message #182160] Thu, 11 January 2007 17:01 Go to next message
Originally posted by: yaning.zhou.thomson.com
I work on linux 64 using eclipse 3.2 and CDT 3.1.1 with linux 64 version.
Everything works exceptI can't run debug. I got above meesage when I
select GDB Debugger.
Any suggestion or solution to it.
Re: CPU doesn't support the debugger [message #182203 is a reply to message #182160] Fri, 12 January 2007 16:48 Go to previous message
Originally posted by: cjashfor.linux.ibm.com
> version. Everything works exceptI can't run debug. I got above meesage
> when I select GDB Debugger.
> Thanks
You might try using a newer CDT (e.g. 4.0Mn) to see if that helps. I
worked on a similar problem for PowerPC 64 Linux.
To use the newer CDT, you'll need the latest Eclipse milestone - 3.3M4 I
think.
- Corey
Corey Ashford
Software Engineer
IBM Linux Technology Center, Linux Toolchain
Beaverton, OR
503-578-3507
cjashfor@us.ibm.com
Previous Topic:Debugging core files using CDT / gdb
Next Topic:Viewing Variable Values Using CDT
Current Time: Mon Sep 01 02:41:57 EDT 2025
Powered by FUDForum. Page generated in 0.06361 seconds
