Home » Language IDEs » Java Development Tools (JDT) » Getting IResource from sourcepath entries
Getting IResource from sourcepath entries [message #182049] Tue, 12 October 2004 05:53 Go to next message
I need to get corresponding IFolder for each project sourcepath entries.
// variable declarations
IProject project;
IJavaProject javaProject;
IClasspathEntry [] entries=javaProject.getResolvedClasspath(true);
for (int i = 0; i < entries.length; i++) {
IClasspathEntry entry=entries[i];
if ( entry.getEntryKind() == IClasspathEntry.CPE_SOURCE ) {
IPath path=entry.getPath();
IFolder folder=project.getWorkspace().getRoot().getFolder(path);
Problem is that it doesn't work if
1) Path is absolute, containing device letters( e.g. c:/projects/test )
2) If path points to project root dir
3) If project sourcepath isn't under eclipse's workspace dir
I tried also with javaProject.getPackageFragmentRoots()
but still same problems ...
So how to get *IFolder* from *absolute* IPath?
thanks
Re: Getting IResource from sourcepath entries [message #182079 is a reply to message #182049] Tue, 12 October 2004 06:46 Go to previous message
1) The path of a source classpath entry must be an absolute
workspace-relative path (see JavaCore#newSourceEntry). "c:/projects/test"
indicates an absolute file system relative path.
2) If the path points to the project, then no corresponding IFolder exists.
You should use getProject(String) in this case:
IContainer container = path.segmentCount() == 1 ?
root.getProject(path.segment(0)) : root.getFolder(path);
3) I'm not sure to understand what you mean here. Even if the location of
the project isn't in the workspace directory, you can still get an IResource
for it.
If you want to use IPackageFragmentRoots, see IJavaElement#getResource().
Jerome
"Tonis" <tvwww@hot.ee> wrote in message news:ckg986$elu$1@eclipse.org...
> IProject project;
> thanks
Previous Topic:eclipse editor shows only a part of the code
Next Topic:launching a clas
Current Time: Thu Oct 30 01:27:39 EDT 2025
Powered by FUDForum. Page generated in 0.04898 seconds
