| Eclipse unstable in Mac OS [message #17162] |
Thu, 08 May 2003 07:41  |
Originally posted by: j.dieckmann.psi-bt.de
Eclipse 2.1 is really a great IDE. I only have 2 complaints when running
Eclipse under Mac OS 10.2.6:
- Eclipse is very slow. I very much hope the performance will be better in
one of the next releases. Are there some informations about optimizations
for mac os?
- Eclipse crashes (about 3 times per hour). The version is stable and "rock
solid" under NT, and XP. I never had a crash when running Eclipse under
these systems. I can't give an exact error report. The situation differs and
the crash is not reproducable. But it chrashes often when I start an ant
task and the console window is not open. Has anyone else made these
observation? Is there something in the settings which could be wrong?
regards
Jan Dieckmann
| Re: Eclipse unstable in Mac OS [message #19092 is a reply to message #17162] |
Fri, 09 May 2003 20:05   |
> for mac os?
I heard the SWT team is working hard to cleanup MacOSX since it became a
primary platform for the Eclipse 2.2 plan.
> observation?
I could make Eclipse 2.1 on macosx 10.2.5 and Java 1.4 crash by closing
a long tree in a java left pane when many jars were present (say, around
50 of them).
The problem is drastically reduced when I moved back to Java 1.3
Apple's version of Java 1.4 is not so solid as they paint it to be. I'm
sure they will come up with a bugfix release soon.
Also, the carbon port of SWT is, well, alpha quality, I would say, for
2.1. The good news is that the SWT team is fully aware of this and they
are focusing on making it better. I think Eclipse on mach-o can only get
better, it's just a matter of time or getting our hands dirty and help
the SWT fix thingg :-)
Oh, did I mention I love eclipse? :-)
If only wasn't this slow on macs :-(
but I just downloaded the lastest integration build and I'll try it out
right after this.
Stefano.
| Re: Eclipse unstable in Mac OS [message #20836 is a reply to message #19092] |
Tue, 13 May 2003 06:14  |
> right after this.
Thank you for your answer. I will go back to Java 1.3. Would you please
report to this newsgroup if the integration build runs better on mac os X?
best regards Jan Dieckmann
FUDForum. Page generated in 0.05921 seconds
