Home » Eclipse Projects » Eclipse Website » Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing
Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17147] |
Mon, 12 June 2006 00:43  |
I'm working on converting the PTP pages http://eclipse.org/ptp to Phoenix.
I downloaded Eclipse 3.1.2, WTP and its prereqs (the convenient
all-in-one download), PHPEclipse, and XAMPP.
I configured PhpEclipse and XAMPP like the instructions said, more or
less (instructions were in a backlevel of some of the parts.)
While the editor does have nice colors of keywords etc.
I cannot get the PHP Browser to work.
I can start XAMPP with the button in the toolbar and it reports
### APACHE + MYSQL IS STARTING NOW ###
If I double-click on a php file I get it in the editor,
but the PHP Browser reports "Access Forbidden! You don't have
permission to access the requested object. It is either read-protected
or not readable by the server."
I've gotten a few pages done at http://eclipse.org/ptp/index2.php
by checking them in and testing there, but I'd prefer to remove
more bugs *before* checking them in.
What am I doing wrong?
Thanks.
....Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17176 is a reply to message #17147] |
Mon, 12 June 2006 15:35   |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
Beth, I don't use Xampp, so I'll try to help you with my eyes closed.
I believe your Apache DocumentRoot folder doesn't match the folder where
your project lies.
Apache maintains a file called "httpd.conf", but the DocumentRoot
setting may be a setting inside Xampp.
Can you look to see if you can find this DocumentRoot setting and/or the
httpd file?
> Thanks.
> ...Beth
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17204 is a reply to message #17176] |
Mon, 12 June 2006 16:04   |
I don't particularly care about xampp, i just want to be able to see the
php pages before i check them in, so if you don't use them, then maybe i
don't need to.
Yes I changed the apache doc root. The apache that got installed with
xamp. I probalby have ibm http server (aka apache) also installed on
this laptop. Would that make a difference?
Hmmm... my doc root points to my workspace. Maybe it needs to point
to the *project* folder in the workspace?
....Beth
> your project lies.
> httpd file?
> Thanks
>> Phoenix.
>> read-protected or not readable by the server."
>> Thanks.
>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17229 is a reply to message #17204] |
Mon, 12 June 2006 17:52   |
Well I changed httpd.conf to point to the project directory of my
eclipse project website files, but it still doesn't work.
If I click on a php file, it shows in the editor but in the PHP browser
I get "this page cannot be displayed."
If I click on the Xampp button it appears to start apache and mySQL.
http://localhost in a web browser gives me "access forbidden"
(as opposed to can't display page, so the web server is running)
as does double-clicking on a php file - what shows in the
PHP browser is also "access forbidden". PHP editor looks okay.
I get syntax highlighting, etc. which is helpful but i need rendering
to see if all those DIV tags etc. match up!
If I stop xampp (stops apache & MySql) and click on "start apache" only,
I get a popup "Apache has encountered an error and needs to close."
What *should* I do when bringing up a phoenix (php) website in eclipse?
Thanks!
> don't need to.
> ...Beth
>> where your project lies.
>> the httpd file?
>> Thanks
>>> Phoenix.
>>> Thanks.
>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17257 is a reply to message #17229] |
Tue, 13 June 2006 04:03   |
Originally posted by: eclipse.bettsockentraeger.de
Have you tested if your xampp installation actually works? Start your
xampp and point your browser at http://localhost/ it should display some
sort of welcome page. If it does not than your xampp is misconfigured.
Several issues could be the case:
1. Does document root point at the correct location
2. Does your xampp user have full access to that directory? If not then
you might get the access forbidden error.
What script is loaded when you start the phpeclipse browser? Maybe it's
mysql that gives you the error. What user are you using to access the db?
Hope that helps
Stefan
> Thanks!
>> the php pages before i check them in, so if you don't use them, then
>> maybe i don't need to.
>> ...Beth
>>> the httpd file?
>>> Thanks
>>>> Phoenix.
>>>> or less (instructions were in a backlevel of some of the parts.)
>>>> Thanks.
>>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17357 is a reply to message #17204] |
Wed, 14 June 2006 13:45   |
I'm thinking your IBM HTTP server is the one attempting to fetch pages
for http://localhost. The fact that Apache does not start correctly
(encountered an error) also indicated that port 80 is already being used.
At this point, you'd need to either remove the IBM http server so that
Xampp's Apache can start, or create an alias in IBM http server (/ptp/)
that points to your project workspace directory (c:/ews/phoenixPTP/ptp)
If IBM http server is based on apache, it should have an httpd.conf
file where you can add
Alias /ptp/ c:/ews/phoenixPTP/ptp
Denis
> don't need to.
> ...Beth
>> the httpd file?
>> Thanks
>>> Phoenix.
>>> Thanks.
>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #17838 is a reply to message #17357] |
Thu, 15 June 2006 15:54   |
Another solution would be to let XAMPP listen on another port. This can
be configured somewhere in the http.conf file.
> Denis
>> ...Beth
>>> the httpd file?
>>> Thanks
>>>> Phoenix.
>>>> Thanks.
>>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569334 is a reply to message #17147] |
your project lies.
httpd file?
> Thanks.
> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569357 is a reply to message #17176] |
don't need to.
....Beth
> your project lies.
> httpd file?
> Thanks
>> Phoenix.
>> Thanks.
>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569373 is a reply to message #17204] |
Thanks!
> don't need to.
> ...Beth
>> the httpd file?
>> Thanks
>>> Phoenix.
>>> Thanks.
>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569427 is a reply to message #17229] |
Hope that helps
Stefan
> Thanks!
>> ...Beth
>>> the httpd file?
>>> Thanks
>>>> Phoenix.
>>>> Thanks.
>>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569476 is a reply to message #17257] |
Tue, 13 June 2006 16:27  |
I start xampp from the button in the toolbar and it says
http://localhost in Firefox says "Access forbidden!"
My apache (part of xampp) httpd.conf includes
DocumentRoot "c:/ews/phoenixPTP/ptp"
That is, indeed, my workspace and project folder location.
I don't have an index.php (not ready to check it in yet)
but am working with index2.php -- could that be it?
http://localhost/index2.php also gives "access forbidden"
(I added an index.php and this didn't help either)
Full access? I'm the only user on this machine and i have full Admin rights.
If I close the PHP Browser view and reopen it, nothing is loaded.
Is that what you are asking?
>Maybe it's mysql that gives you the error. What user are you using to
>access the db?
Just me, the only user.
PHPBrowser correctly shows e.g. http://eclipse.org
All the "external tools" preferences look like they point to the
files in my installation.
HEY, the preferences (PHPeclipse>Project Defaults) included a
DocumentRoot setting that differed from httpd.conf!
I fixed it and restarted xampp and still get access forbidden.
Restarted eclipse, restarted xampp and still get it.
Also, I don't have the include files from Denis' on the eclipse.org
phoenix website. do i need them?
The first line of php file includes
require_once($_SERVER['DOCUMENT_ROOT'] .
"/eclipse.org-common/system/app.class.php");
"/eclipse.org-common/system/nav.class.php");
"/eclipse.org-common/system/menu.class.php"); $App = new App(); $Nav =
new Nav(); $Menu = new Menu(); include($App->getProjectCommon()); #
All on the same line to unclutter the user's desktop'
Thanks for any help!
> Hope that helps
> Regards
> Stefan
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569528 is a reply to message #17308] |
Wed, 14 June 2006 03:51  |
I'm assuming you are on a windows machine.
Try specifiing the document root without c:. For this to work apache
(XAMPP) must be installed on the same drive. Or try using backslash
instead of normal slash. It might be that the path is not correctly
interpreted.
For testing purposes it would be helpful to use the following index.php
<?php
phpinfo();
This will simply print out information about your php installation. If
you see this page without any warnings then XAMPP is correctly setup.
Stefan
> rights.
> >access the db?
> App(); $Nav = new Nav(); $Menu = new Menu();
> include($App->getProjectCommon()); # All on the same line to
>> some sort of welcome page. If it does not than your xampp is
>> misconfigured. Several issues could be the case:
>> then you might get the access forbidden error.
>> it's mysql that gives you the error. What user are you using to access
>> the db?
>> Hope that helps
>> Regards
>> Stefan
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569548 is a reply to message #17204] |
for http://localhost The fact that Apache does not start correctly
Denis
> don't need to.
> ...Beth
>> the httpd file?
>> Thanks
>>> Phoenix.
>>> Thanks.
>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569612 is a reply to message #17357] |
> Denis
>> ...Beth
>>> the httpd file?
>>> Thanks
>>>> Phoenix.
>>>> Thanks.
>>>> ...Beth
Re: Unable to get WTP/PHPEclipse/XAMPP to work for Phoenix pages testing [message #569625 is a reply to message #17147] |
Mon, 19 June 2006 16:13  |
To answer my own question:
The problem was that in the httpd.conf, there are TWO
places to change DocumentRoot.
This was documented:
But this wasn't:
<Directory "c:/ews/phoenixPTP/ptp">
I know, I know, I should have read the comments in the httpd.conf :-)
The PhpBrowser now tries to do something.
Now I need to find those include files...
eclipse.org-common/system/app.class.php, etc...
....Beth
Current Time: Sat Jul 26 10:02:53 EDT 2025
Powered by FUDForum. Page generated in 0.31675 seconds
