| Report publishing problem [message #181681] |
Wed, 02 August 2006 05:38  |
Originally posted by: gerhard.goosen.bluesphere.co.za
Hi, I'm pretty new to BIRT , And I am trying to figure out something. I
have downloaded the example report from the BIRT HOME and I am
previewing it, in Eclipse. It work fine. but when I publish it to my
BIRT web viewer and I try to run it there it says my report has errors
and it cant be run... what is happening here? What am I doing wrong...
Am I misunderstanding the concept of publishing or what? Any help will
be much appreciated.
Thanks.
Gerhard
| Re: Report publishing problem [message #183301 is a reply to message #183061] |
Tue, 08 August 2006 04:24   |
Hi Jason, yes when running the .rtpdesign the report works fine... so i
guess I totally misunderstood the publishing thing! Can you tell me if
there is a mechanism in BIRT that will save my .rptdesign files in a
remote folder, like my web viewer's report folder??? Thanks
Jason Weathersby wrote:
> Gerhard,
> It should not be named rpttemplate. This is the extension for a report
> template, not a rpt design.
> If you try the index.jsp page in the WebViewerExample you will see a link
> for the test.rptdesign.
> Does this work on your system?
> When you are building a report make sure you select new report not new
> template.
> Templates are used by report designs.
> Jason
> "Gerhard Goosen" <gerhard.goosen@bluesphere.co.za> wrote in message
> news:eb7ev8$r9i$1@utils.eclipse.org...
>> I have copied the test.rptdesign report that comes with the birt-viewer
>> web application. That I got from downloading the birt-runtime-2_0_1.zip
>> into me workspace i did not edit it at all, i only published it to my
>> birt-viewer's report folder.
>> I get a error on the viewer side... attached is the report design and
>> the log file created...
>> note: The report .rptdesign works like a charm when I "preview" in
>> Eclipse. but not when published... it checnges the name to .rpttemplate???
>> thanks
>>> What error are you getting?
>>> Can you check the Tomcat logs directory?
>>> Also in the web.xml there is a setting for logging.
>>> Change it to FINEST and set a location for the fle.
>>> Post the log.
>>> Thanks
>>> Jason
>>> "jan " <10-1985@gmx.de> wrote in message
>>> news:940f40f99bca6abc1529e6703a11e584$1@www.eclipse.org...
>>>> sounds like my problem,
>>>> Report is very tiny,but same problem with example
>>>> testWebReport.rptdesign
>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>> <!-- Written by Eclipse BIRT 2.0 -->
>>>> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
>>>> id="1">
>>>> <property name="createdBy">Eclipse BIRT Designer Version
>>>> 2.1.0.N20060628-1351 Build <20060628-1537></property>
>>>> <property name="units">in</property>
>>>> <property name="comments">Copyright (c) 2006 <<Your Company
>>>> Name
>>>> here>></property>
>>>> <page-setup>
>>>> <simple-master-page name="Simple MasterPage" id="2">
>>>> <page-footer>
>>>> <text id="3">
>>>> <property name="contentType">html</property>
>>>> <text-property name="content"><![CDATA[<value-of>new
>>>> Date()</value-of>]]></text-property>
>>>> </text>
>>>> </page-footer>
>>>> </simple-master-page>
>>>> </page-setup>
>>>> <body>
>>>> <text id="4">
>>>> <property name="contentType">plain</property>
>>>> <text-property
>>>> name="content"><![CDATA[ffdsa]]></text-property>
>>>> </text>
>>>> </body>
>>>> </report>
>> 2006/08/07 03:08:14 org.eclipse.birt.core.util.BirtTimer logTimeTaken
>> INFO: Engine startup takes 531 Milliseconds.
>> 2006/08/07 03:08:15
>> org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
>> FINE: return internal name for choice eq
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice asc
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice all
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice hide
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice any
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice if-realized
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice auto
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice hyperlink
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice string
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice static
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice normal
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice none
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice scroll
>> 2006/08/07 03:08:15
>> org.eclipse.birt.report.model.metadata.DimensionPropertyType validateXml
>> FINE: return dimension value with user defined unit 0%
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice repeat
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice left
>> 2006/08/07 03:08:15
>> FINE: return dimension value with user defined unit 0em
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice block
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return dimension value with user defined unit 0pt
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return dimension value with user defined unit 1in
>> 2006/08/07 03:08:15
>> FINE: return dimension value with user defined unit 1.25in
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return dimension value with user defined unit 0.5pt
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice size-to-image
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> FINE: return internal name for choice horizontal
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> 2006/08/07 03:08:15
>> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper
>> openReportDesign
>> SEVERE: invalid design file C:\Program Files\Apache Software
>> Foundation\Tomcat 5.0\webapps\birt-viewer\report\test.rpttemplate
>> id="1">
>> <property name="author">Bertie the Platypus</property>
>> <property name="createdBy">Eclipse BIRT Designer Version 1.0.0 Build
>> <20050405-1230></property>
>> <property name="comments">Not a very interesting report, just a "Hello
>> World" with a param.</property>
>> <html-property name="description">Sample report used to test the BIRT
>> viewer.</html-property>
>> <list-property name="configVars">
>> <structure>
>> <property name="name">sample</property>
>> <property name="value">aaa</property>
>> </structure>
>> </list-property>
>> <parameters>
>> <scalar-parameter name="sample" id="2">
>> <text-property name="displayName">Sample
>> Parameter</text-property>
>> <property name="hidden">false</property>
>> <property name="dataType">string</property>
>> <property name="concealValue">false</property>
>> <property name="allowBlank">true</property>
>> <property name="allowNull">false</property>
>> <property name="controlType">text-box</property>
>> <property name="mustMatch">false</property>
>> <property name="fixedOrder">false</property>
>> </scalar-parameter>
>> </parameters>
>> <page-setup>
>> <simple-master-page name="Simple MasterPage" id="3">
>> <page-header>
>> <grid id="4">
>> <property name="width">100%</property>
>> <column id="5"/>
>> <row id="6">
>> <cell id="7">
>> <property name="fontSize">xx-large</property>
>> <property name="fontWeight">bold</property>
>> <property name="textAlign">center</property>
>> <text id="8">
>> <text-property
>> name="content"><![CDATA[Title]]></text-property>
>> </text>
>> </cell>
>> </row>
>> </grid>
>> </page-header>
>> <page-footer>
>> <grid id="9">
>> <column id="10"/>
>> <column id="11"/>
>> <row id="12">
>> <cell id="13">
>> <text id="14">
>> <property
>> <text-property
>> name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
>> </text>
>> </cell>
>> <cell id="15">
>> <property name="textAlign">right</property>
>> <text id="16">
>> <text-property
>> name="content"><![CDATA[Page:]]></text-property>
>> </text>
>> </cell>
>> </row>
>> </grid>
>> </page-footer>
>> </page-setup>
>> <body>
>> <text id="17">
>> <text-property name="content"><![CDATA[<b>Congratulations!</b>
>> <br><br>
>> If you can see this report, it means that the BIRT viewer is installed
>> correctly.
>> <br><br>]]></text-property>
>> </text>
>> <grid id="18">
>> <column id="19">
>> <property name="width">1.354in</property>
>> </column>
>> <column id="20">
>> <property name="width">5.083in</property>
>> </column>
>> <row id="21">
>> <cell id="22">
>> <label id="23">
>> <text-property name="text">Sample
>> Parameter:</text-property>
>> </label>
>> </cell>
>> <cell id="24">
>> <data id="25">
>> <list-property name="boundDataColumns">
>> <structure>
>> <property
>> name="name">params["sample"]</property>
>> <expression
>> name="expression">params["sample"]</expression>
>> </structure>
>> </list-property>
>> <property
>> name="resultSetColumn">params["sample"]</property>
>> </data>
>> </cell>
>> </row>
>> </grid>
>> </body>
>> </report>
| Re: Report publishing problem [message #183467 is a reply to message #183301] |
Tue, 08 August 2006 12:43   |
The rpttemplate can be published to a resource folder, which is set in
preferences. This is meant to ease development so
Templates paths dont have to be hard coded.
Rptdesigns dont have this structure. You to have export the rptdesigns.
Jason
news:eb9hnu$sou$1@utils.eclipse.org...
>> Gerhard,
>> template.
>> Jason
>>> Hi,
>>> .rpttemplate???
>>> thanks
>>>> Post the log.
>>>> Thanks
>>>> Jason
>>>>> version="3.2.2"
>>>>> id="1">
>>>>> Name
>>>>> here>></property>
>>>>> <page-setup>
>>>>> <page-footer>
>>>>> <text id="3">
>>>>> <text-property
>>>>> </text>
>>>>> </page-footer>
>>>>> </page-setup>
>>>>> <body>
>>>>> <text id="4">
>>>>> <text-property
>>>>> </text>
>>>>> </body>
>>>>> </report>
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> 2006/08/07 03:08:15
>>> openReportDesign
>>> id="1">
>>> "Hello World" with a param.</property>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <parameters>
>>> </scalar-parameter>
>>> </parameters>
>>> <page-setup>
>>> <page-header>
>>> <grid id="4">
>>> <column id="5"/>
>>> <row id="6">
>>> <cell id="7">
>>> <text id="8">
>>> <text-property
>>> </text>
>>> </cell>
>>> </row>
>>> </grid>
>>> </page-header>
>>> <page-footer>
>>> <grid id="9">
>>> <column id="10"/>
>>> <column id="11"/>
>>> <row id="12">
>>> <cell id="13">
>>> <text id="14">
>>> <property
>>> <text-property
>>> </text>
>>> </cell>
>>> <cell id="15">
>>> <text id="16">
>>> <text-property
>>> </text>
>>> </cell>
>>> </row>
>>> </grid>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <text id="17">
>>> <text-property
>>> <br><br>
>>> correctly.
>>> </text>
>>> <grid id="18">
>>> <column id="19">
>>> </column>
>>> <column id="20">
>>> </column>
>>> <row id="21">
>>> <cell id="22">
>>> <label id="23">
>>> </label>
>>> </cell>
>>> <cell id="24">
>>> <data id="25">
>>> <structure>
>>> <property
>>> <expression
>>> </structure>
>>> </list-property>
>>> <property
>>> </data>
>>> </cell>
>>> </row>
>>> </grid>
>>> </body>
>>> </report>
| Re: Report publishing problem [message #184189 is a reply to message #183467] |
Thu, 10 August 2006 03:15   |
ok cool thanks. Is there a mechanism in birt/eclipse that will allow me
to export my designs without extending the birt source code...
Gerhard.
> Jason
>>> Gerhard,
>>> template.
>>> Jason
>>>> Hi,
>>>> .rpttemplate???
>>>> thanks
>>>>> Post the log.
>>>>> Thanks
>>>>> Jason
>>>>>> version="3.2.2"
>>>>>> id="1">
>>>>>> Name
>>>>>> here>></property>
>>>>>> <page-setup>
>>>>>> <page-footer>
>>>>>> <text id="3">
>>>>>> <text-property
>>>>>> </text>
>>>>>> </page-footer>
>>>>>> </page-setup>
>>>>>> <body>
>>>>>> <text id="4">
>>>>>> <text-property
>>>>>> </text>
>>>>>> </body>
>>>>>> </report>
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> 2006/08/07 03:08:15
>>>> openReportDesign
>>>> id="1">
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <parameters>
>>>> </scalar-parameter>
>>>> </parameters>
>>>> <page-setup>
>>>> <page-header>
>>>> <grid id="4">
>>>> <column id="5"/>
>>>> <row id="6">
>>>> <cell id="7">
>>>> <text id="8">
>>>> <text-property
>>>> </text>
>>>> </cell>
>>>> </row>
>>>> </grid>
>>>> </page-header>
>>>> <page-footer>
>>>> <grid id="9">
>>>> <column id="10"/>
>>>> <column id="11"/>
>>>> <row id="12">
>>>> <cell id="13">
>>>> <text id="14">
>>>> <property
>>>> <text-property
>>>> </text>
>>>> </cell>
>>>> <cell id="15">
>>>> <text id="16">
>>>> <text-property
>>>> </text>
>>>> </cell>
>>>> </row>
>>>> </grid>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <text id="17">
>>>> <text-property
>>>> <br><br>
>>>> correctly.
>>>> </text>
>>>> <grid id="18">
>>>> <column id="19">
>>>> </column>
>>>> <column id="20">
>>>> </column>
>>>> <row id="21">
>>>> <cell id="22">
>>>> <label id="23">
>>>> </label>
>>>> </cell>
>>>> <cell id="24">
>>>> <data id="25">
>>>> <structure>
>>>> <property
>>>> <expression
>>>> </structure>
>>>> </list-property>
>>>> <property
>>>> </data>
>>>> </cell>
>>>> </row>
>>>> </grid>
>>>> </body>
>>>> </report>
| Re: Report publishing problem [message #184204 is a reply to message #184189] |
Thu, 10 August 2006 10:26   |
Are you wanting an API to export?
You want something other than right clicking on the report and selecting
export?
Jason
news:ebemet$8ng$1@utils.eclipse.org...
> ok cool thanks. Is there a mechanism in birt/eclipse that will allow me to
> Regards
> Gerhard.
>> Jason
>>>> Gerhard,
>>>> link for the test.rptdesign.
>>>> template.
>>>> Jason
>>>>> Hi,
>>>>> birt-viewer
>>>>> .rpttemplate???
>>>>> thanks
>>>>>> Post the log.
>>>>>> Thanks
>>>>>> Jason
>>>>>>> version="3.2.2"
>>>>>>> id="1">
>>>>>>> Name
>>>>>>> here>></property>
>>>>>>> <page-setup>
>>>>>>> <page-footer>
>>>>>>> <text id="3">
>>>>>>> <text-property
>>>>>>> </text>
>>>>>>> </page-footer>
>>>>>>> </page-setup>
>>>>>>> <body>
>>>>>>> <text id="4">
>>>>>>> <text-property
>>>>>>> </text>
>>>>>>> </body>
>>>>>>> </report>
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> validateXml
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> 2006/08/07 03:08:15
>>>>> openReportDesign
>>>>> version="3.2.2" id="1">
>>>>> Build <20050405-1230></property>
>>>>> BIRT viewer.</html-property>
>>>>> <structure>
>>>>> </structure>
>>>>> </list-property>
>>>>> <parameters>
>>>>> </scalar-parameter>
>>>>> </parameters>
>>>>> <page-setup>
>>>>> <page-header>
>>>>> <grid id="4">
>>>>> <column id="5"/>
>>>>> <row id="6">
>>>>> <cell id="7">
>>>>> <property
>>>>> <property
>>>>> <text id="8">
>>>>> <text-property
>>>>> </text>
>>>>> </cell>
>>>>> </row>
>>>>> </grid>
>>>>> </page-header>
>>>>> <page-footer>
>>>>> <grid id="9">
>>>>> <column id="10"/>
>>>>> <column id="11"/>
>>>>> <row id="12">
>>>>> <cell id="13">
>>>>> <text id="14">
>>>>> <property
>>>>> <text-property
>>>>> </text>
>>>>> </cell>
>>>>> <cell id="15">
>>>>> <text id="16">
>>>>> <text-property
>>>>> </text>
>>>>> </cell>
>>>>> </row>
>>>>> </grid>
>>>>> </page-footer>
>>>>> </page-setup>
>>>>> <body>
>>>>> <text id="17">
>>>>> <text-property
>>>>> <br><br>
>>>>> correctly.
>>>>> </text>
>>>>> <grid id="18">
>>>>> <column id="19">
>>>>> </column>
>>>>> <column id="20">
>>>>> </column>
>>>>> <row id="21">
>>>>> <cell id="22">
>>>>> <label id="23">
>>>>> </label>
>>>>> </cell>
>>>>> <cell id="24">
>>>>> <data id="25">
>>>>> <structure>
>>>>> <property
>>>>> <expression
>>>>> </structure>
>>>>> </list-property>
>>>>> <property
>>>>> </data>
>>>>> </cell>
>>>>> </row>
>>>>> </grid>
>>>>> </body>
>>>>> </report>
| Re: Report publishing problem [message #184231 is a reply to message #184204] |
Fri, 11 August 2006 03:13   |
Hi Jason, The right click export only works if you export to a local or
networked file system, and I need to throw it across HTTP to a WEBDAV
folder, and BIRT from eclipse does not seem to want to do that?
any suggestions?
> export?
> Jason
>> Regards
>> Gerhard.
>>> Jason
>>>>> Gerhard,
>>>>> template.
>>>>> Jason
>>>>>> Hi,
>>>>>> birt-viewer
>>>>>> .rpttemplate???
>>>>>> thanks
>>>>>>> Post the log.
>>>>>>> Thanks
>>>>>>> Jason
>>>>>>>> version="3.2.2"
>>>>>>>> id="1">
>>>>>>>> Name
>>>>>>>> here>></property>
>>>>>>>> <page-setup>
>>>>>>>> <page-footer>
>>>>>>>> <text id="3">
>>>>>>>> <text-property
>>>>>>>> </text>
>>>>>>>> </page-footer>
>>>>>>>> </page-setup>
>>>>>>>> <body>
>>>>>>>> <text id="4">
>>>>>>>> <text-property
>>>>>>>> </text>
>>>>>>>> </body>
>>>>>>>> </report>
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> validateXml
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> 2006/08/07 03:08:15
>>>>>> openReportDesign
>>>>>> <structure>
>>>>>> </structure>
>>>>>> </list-property>
>>>>>> <parameters>
>>>>>> </scalar-parameter>
>>>>>> </parameters>
>>>>>> <page-setup>
>>>>>> <page-header>
>>>>>> <grid id="4">
>>>>>> <column id="5"/>
>>>>>> <row id="6">
>>>>>> <cell id="7">
>>>>>> <property
>>>>>> <property
>>>>>> <text id="8">
>>>>>> <text-property
>>>>>> </text>
>>>>>> </cell>
>>>>>> </row>
>>>>>> </grid>
>>>>>> </page-header>
>>>>>> <page-footer>
>>>>>> <grid id="9">
>>>>>> <column id="10"/>
>>>>>> <column id="11"/>
>>>>>> <row id="12">
>>>>>> <cell id="13">
>>>>>> <text id="14">
>>>>>> <property
>>>>>> <text-property
>>>>>> </text>
>>>>>> </cell>
>>>>>> <cell id="15">
>>>>>> <text id="16">
>>>>>> <text-property
>>>>>> </text>
>>>>>> </cell>
>>>>>> </row>
>>>>>> </grid>
>>>>>> </page-footer>
>>>>>> </page-setup>
>>>>>> <body>
>>>>>> <text id="17">
>>>>>> <text-property
>>>>>> <br><br>
>>>>>> correctly.
>>>>>> </text>
>>>>>> <grid id="18">
>>>>>> <column id="19">
>>>>>> </column>
>>>>>> <column id="20">
>>>>>> </column>
>>>>>> <row id="21">
>>>>>> <cell id="22">
>>>>>> <label id="23">
>>>>>> </label>
>>>>>> </cell>
>>>>>> <cell id="24">
>>>>>> <data id="25">
>>>>>> <structure>
>>>>>> <property
>>>>>> <expression
>>>>>> </structure>
>>>>>> </list-property>
>>>>>> <property
>>>>>> </data>
>>>>>> </cell>
>>>>>> </row>
>>>>>> </grid>
>>>>>> </body>
>>>>>> </report>
FUDForum. Page generated in 0.07082 seconds
