Home » Language IDEs » ServerTools (WTP) » WAR validation failure -- but it has no effect
WAR validation failure -- but it has no effect [message #181572] Thu, 12 October 2006 13:57 Go to next message
I'm getting the an error reported in problems view when I build my dynamic
web project using the web.xml shown below.
If I click on the error message, eclipse ignores the click and does not
activate the web.xml file. There are no errors flaged in the web.xml
editor, and the project deploys and executes correctly.
If everything works well, why am I getting this error?
Michael Giroux
CHKJ3000E: WAR Validation Failed:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.De ploymentDescriptorLoadException:
WEB-INF/web.xml TestProjectEJB3 Unknown 1160675451248 1169732
<web-app id="WebApp_ID" version="2.4"
xmlns="http://java.sun.com/xml/ns/j2ee"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
<display-name>TestProjectEJB3</display-name>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value> classpath:/com/bull/test/services-generationtestproject-cont ext.xml,
classpath:/com/bull/test/config-context.xml</param-value>
</context-param>
<!-- Listener, that does all the startup work (configuration, init). -->
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener </listener-class>
</listener>
<servlet>
<description>Test for the EJB3 business code</description>
<display-name>TestServlet</display-name>
<servlet-name>TestServlet</servlet-name>
<servlet-class>com.bull.test.TestServlet</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/TestServlet</url-pattern>
</servlet-mapping>
</web-app>
Re: WAR validation failure -- but it has no effect [message #181643 is a reply to message #181572] Fri, 13 October 2006 09:17 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Michael,
I pasted your web.xml in an empty web project and created even the TestServlet,
but I did not see an error.
What is your WTP version ? I checked it with 1.5.0.
Do you see an exception in "workspace\.metadata\.log" ?
Does it also happen with a clean workspace ?
Best regards
Wolfgang
> Michael Giroux
Re: WAR validation failure -- but it has no effect [message #181653 is a reply to message #181643] Fri, 13 October 2006 11:39 Go to previous message
Eclipse 3.2.1 + WTP 1.5.1
1. I'm including the exceptions that were thrown.
2. I created a new workspace and imported the project using the "copy
files" option. The new project did not have the error.
3. Guessing there might be something wrong in the original workspace, I went
back to the original workspace and did the following:
a. rename web.xml to w.x
b.build the project
c. rename w.x to web.xml
d build the project
Following this sequence, the error has been eliminated. I did not make any
changes to web.xml other than to rename it. My guess is that renaming it
cleared something that was being cached.
Michael Giroux
!ENTRY org.eclipse.wst.validation 4 0 2006-10-12 11:06:26.626
!MESSAGE
*** ERROR ***: Thu Oct 12 11:06:26 GMT-07:00 2006
org.eclipse.wst.validation.internal.core.ValidationException : CHKJ3000E: WAR
Validation Failed:
WEB-INF/web.xml
org.eclipse.jst.j2ee.model.internal.validation.WarValidator. validateInJob(WarValidator.java:295)
org.eclipse.jst.j2ee.internal.web.validation.UIWarValidator. validateInJob(UIWarValidator.java:92)
org.eclipse.wst.validation.internal.operations.ValidatorJob. run(ValidatorJob.java:70)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.wst.validation 4 0 2006-10-12 11:06:26.642
!MESSAGE
WEB-INF/web.xml
Stack trace of nested exception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:357)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
org.eclipse.wst.common.internal.emfworkbench.WorkbenchResour ceHelper.getOrCreateResource(WorkbenchResourceHelper.java:38 4)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getResource(EditModel.java:680)
org.eclipse.wst.common.componentcore.internal.ArtifactEditMo del.getResource(ArtifactEditModel.java:174)
org.eclipse.wst.common.componentcore.ArtifactEdit.getResourc e(ArtifactEdit.java:636)
org.eclipse.jst.j2ee.internal.archive.operations.ComponentLo adStrategyImpl.getMofResource(ComponentLoadStrategyImpl.java :467)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.getMofResource(ArchiveImpl.java:731)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleF ileImpl.getDeploymentDescriptorResource(ModuleFileImpl.java: 61)
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Xml BasedImportStrategyImpl.primLoadDeploymentDescriptor(XmlBase dImportStrategyImpl.java:39)
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.War 22ImportStrategyImpl.loadDeploymentDescriptor(War22ImportStr ategyImpl.java:87)
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.War 22ImportStrategyImpl.importMetaData(War22ImportStrategyImpl. java:81)
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.WARFile Impl.getDeploymentDescriptor(WARFileImpl.java:145)
org.eclipse.jst.j2ee.model.internal.validation.WarValidator. validateInJob(WarValidator.java:280)
Previous Topic:Eclipse 3.2.1 + WTP 1.5.1 -- JSP, JSP Fragment, Taglib + Validation = Noise
Next Topic:Dynamic Web project builds automatically with Build Automatically OFF
Current Time: Sat Jun 21 14:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.05138 seconds
