| Getting the source... [message #181557] |
Sun, 18 January 2004 03:58  |
Originally posted by: ronm.p-cube.com
Hello Guys.
I want to get source files from the Eclipse Project (actually I want to
download the Java Editor Plug-In example, to start and learn about Ecplise
plug-ins. So how do I go about doing it?
So I know the editor is under org.eclipse.ui.examples.javaeditor
But how do I actually get all the files (Sync or Get_Latest or whatever it
is called in CVS)?
Ron M.
P-Cube LTD.
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
| Re: Getting the source... [message #181892 is a reply to message #181837] |
Mon, 19 January 2004 01:35  |
Thanks Ed.
I also found out that you can download the whole eclipse source code from
the download pages. Man, these pages are so badly written - why is the
source code in the same list as the builds? (Windows, Linux...Source).
It's quite silly...
Ron M.
P-Cube LTD.
On Sun, 18 Jan 2004 21:03:55 -0500, Ed Burnette
<ed.burnette@REMOVE.THIS.sas.com> wrote:
> Assuming you have the Eclipse SDK and the example package installed,
> you already have the source code without resorting to CVS
> to view it. Within Eclipse select File > Import > External Plug-ins
> and Fragments. Import all the plug-ins this way and you'll have full
> access to the source code (and a lot of projects in your workspace
> but you can filter them out when you don't need them). Drill
> down on a plug-in, hover over class references in your source and
> Ctrl-click
> on them, or use the Navigate > Open Type menu (Ctrl-Shift-T by default)
> to
> look for things.
> Ed Burnette, co-author, Eclipse in Action
> www.eclipsepowered.org
> "Ron Mertens" <ronm@p-cube.com> wrote in message
> news:opr1yq8kxan4ig2f@localhost...
>> Ecplise
>> it
>> is called in CVS)?
FUDForum. Page generated in 0.03842 seconds
