Home » Newcomers » Newcomers » elements in a GROUP are not visible
elements in a GROUP are not visible [message #181553] Fri, 24 November 2006 06:17 Go to next message
Originally posted by: brahim.zemmit.alcatel.de
hello,
I'm trying to fill the view part of an RCP client example with the
following code, and i don't know why the elements inside the Group are not
visible!
Can anybody help me?
Thank you
public class View extends ViewPart {
public static final String ID = "app.view";
public void createPartControl(Composite parent) {
RowLayout fl = new RowLayout();
parent.setLayout(fl);
Group frame = new Group(parent, SWT.NONE);
frame.setSize(400,100);
frame.setText("GROUP ");
frame.setToolTipText("Tooltip");
frame.setBackground(new Color(null,0xEE,0xEE,0xEE));
Label label = new Label(frame, SWT.SHADOW_ETCHED_IN);
label.setText("Label");
label.setEnabled(true);
frame.pack();
Text text = new Text(frame, SWT.SHADOW_ETCHED_IN);
text.setLocation(50, 100);
Re: elements in a GROUP are not visible [message #181711 is a reply to message #181553] Fri, 24 November 2006 11:09 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Brahim Zemmit wrote:
> hello,
> not visible!
> Thank you
> frame.pack();
I'm not exactly sure, but I think it is discouraged to change the layout
of a your parent composite when creating a ViewPart.
The Group widget is a composite, so it has its own layout. Have you
tried setting the layout on the Group instead of on the parent?
frame.setLayout(fl) instead of parent.setLayout(fl);
Re: elements in a GROUP are not visible [message #181788 is a reply to message #181711] Mon, 27 November 2006 07:25 Go to previous message
Thank you David,
setting the layout on the Group instead of on the parent works fine!
Previous Topic:how do I get early access to 64-bit versions?
Next Topic:Can the system editor be changed?
Current Time: Mon Dec 01 16:15:38 EST 2025
Powered by FUDForum. Page generated in 0.49814 seconds
