Home » Newcomers » Newcomers » Failed start - Error loading hook
| Failed start - Error loading hook [message #181292] |
Wed, 22 November 2006 09:40  |
Originally posted by: wjsx9999.yahoo.com
Can't figure out why the EclipseAdaptorHook class def can't be found.
Directory location for eclipse files doesn't seem to make any difference.
Even put Eclipse directories in CLASSPATH variable.
I welcome any suggestions.
!SESSION 2006-11-22 09:01:33.380
eclipse.buildId=M20060921-0945
java.fullversion=GNU libgcj 3.4.4 20050314 (prerelease) (Debian
3.4.3-13sarge1)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 4 0 2006-11-22 09:01:35.340
!MESSAGE error loading hook:
org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook
!STACK 0
java.lang.NoClassDefFoundError: while resolving class:
at java.lang.VMClassLoader.resolveClass(java.lang.Class)
(/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String, boolean,
java.lang.ClassLoader) (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String) (/usr/lib/libgcj.so.5.0.0)
org.eclipse.osgi.baseadaptor.HookRegistry.loadConfigurators( java.util.ArrayList,
java.util.ArrayList) (Unknown Source)
at org.eclipse.osgi.baseadaptor.HookRegistry.initialize() (Unknown
Source)
org.eclipse.osgi.baseadaptor.BaseAdaptor.BaseAdaptor(java.la ng.String[])
(Unknown Source)
at _Jv_CallAnyMethodA(java.lang.Object, java.lang.Class, _Jv_Method,
boolean, boolean, java.lang.Class[], jvalue, jvalue, boolean)
boolean, java.lang.Class[], java.lang.Object[]) (/usr/lib/libgcj.so.5.0.0)
at java.lang.reflect.Constructor.newInstance(java.lang.Object[] )
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdapto r()
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at java.lang.reflect.Method.invoke(java.lang.Object,
at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[],
java.net.URL[]) (Unknown Source)
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
Caused by: java.lang.ClassNotFoundException:
org.xml.sax.helpers.DefaultHandler not found in
[file:/usr/local/apps/eclipse/plugins/org.eclipse.osgi_3.2.1 .R32x_v20060919.jar]
at java.net.URLClassLoader.findClass(java.lang.String)
at java.lang.ClassLoader.loadClass(java.lang.String, boolean)
at _Jv_FindClass(_Jv_Utf8Const, java.lang.ClassLoader)
at _Jv_ClassReader.handleClassBegin(int, int, int)
at _Jv_ClassReader.parse() (/usr/lib/libgcj.so.5.0.0)
at _Jv_DefineClass(java.lang.Class, byte[], int, int)
at java.lang.VMClassLoader.defineClass(java.lang.ClassLoader,
java.lang.String, byte[], int, int, java.security.ProtectionDomain)
at java.lang.ClassLoader.defineClass(java.lang.String, byte[], int,
int, java.security.ProtectionDomain) (/usr/lib/libgcj.so.5.0.0)
at java.security.SecureClassLoader.defineClass(java.lang.String ,
byte[], int, int, java.security.CodeSource) (/usr/lib/libgcj.so.5.0.0)
at _Jv_PrepareCompiledClass(java.lang.Class) (/usr/lib/libgcj.so.5.0.0)
at _Jv_WaitForState(java.lang.Class, int) (/usr/lib/libgcj.so.5.0.0)
at java.lang.VMClassLoader.linkClass0(java.lang.Class)
...19 more
!ENTRY org.eclipse.osgi 4 0 2006-11-22 09:01:35.944
!MESSAGE Startup error
!STACK 1
java.lang.Error: Not implemented
at java.nio.channels.FileChannelImpl.tryLock(long, long, boolean)
at java.nio.channels.FileChannel.tryLock() (/usr/lib/libgcj.so.5.0.0)
at org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.loc k()
(Unknown Source)
at org.eclipse.osgi.storagemanager.StorageManager.lock(boolean)
(Unknown Source)
at org.eclipse.osgi.storagemanager.StorageManager.open(boolean)
(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileMa nager(java.io.File,
java.lang.String, boolean) (Unknown Source)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize (org.eclipse.osgi.baseadaptor.BaseAdaptor)
(Unknown Source)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage()
(Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.Framework.Framework (org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(org.eclipse.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
org.eclipse.osgi.framework.internal.core.OSGi.OSGi(org.eclip se.osgi.framework.adaptor.FrameworkAdaptor)
(Unknown Source)
Source)
Source)
Source)
!SESSION Wed Nov 22 09:01:35 GMT-05:00 2006
!ENTRY org.eclipse.core.launcher 4 0 2006-11-22 09:01:35.995
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Source)
Source)
Source)
| Re: Failed start - Error loading hook [message #181355 is a reply to message #181292] |
Wed, 22 November 2006 13:17  |
> difference. Even put Eclipse directories in CLASSPATH variable.
Download, install, and use a different Java... Sun's, BEA's, IBM's...
but not gcj.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Current Time: Wed Nov 05 20:01:05 EST 2025
Powered by FUDForum. Page generated in 0.08716 seconds
