Home » Modeling » GMF (Graphical Modeling Framework) » Disable Modeling Assistant
Disable Modeling Assistant [message #181172] Mon, 07 April 2008 08:57 Go to next message
Originally posted by: nico.lammers.gmail.com
How can this be done? I read something somewhere about the editpolicies,
but I think these editpolicies are installed in the GMF runtime editpart
superclass?
I can't find anything in the gmfgen either..
How can this be done in an easy way? I really need to remove it...
~ Nico Lammers
Re: Disable Modeling Assistant [message #181245 is a reply to message #181172] Mon, 07 April 2008 11:57 Go to previous messageGo to next message
Hello Nico,
I think it should be configurable via diagram properties.
Alex Shatalin
Re: Disable Modeling Assistant [message #181344 is a reply to message #181245] Tue, 08 April 2008 05:18 Go to previous messageGo to next message
Do you mean the preference pages? Because I'd rather do this at
runtime.. they should never be enabled in my case.
~ Nico
Alex Shatalin wrote:
> Hello Nico,
> Alex Shatalin
Re: Disable Modeling Assistant [message #181377 is a reply to message #181344] Tue, 08 April 2008 06:14 Go to previous message
Hello Nico,
Yes.
See generated DiagramGeneralPreferencePage - you can override default behaviour
there. I think this property is called "IPreferenceConstants.PREF_SHOW_POPUP_BARS".
Alex Shatalin
Previous Topic:Problems with copy/paste
Next Topic:Hidden / Invisible nodes are selectable
Current Time: Sat Jun 21 19:03:45 EDT 2025
Powered by FUDForum. Page generated in 0.06073 seconds
