| RAP Demo on Tomcat [message #17097] |
Tue, 17 April 2007 07:39  |
Originally posted by: liat_golan_herman.walla.co.il
What are the steps to deploy eclipse RAP Demo to the tomcat?
I am able to run it using the eclipse but don't know what is required for
the tomcat deployment.
Liat
| Re: RAP Demo on Tomcat [message #19875 is a reply to message #19831] |
Mon, 23 April 2007 05:10  |
Originally posted by: fappel.innoopract.com
I just checked the CVS - the current version number of the
deployment_tutorial.html is 1.1, so it is in the repository. It is true that
the 'org.eclipse.rap.demo.feature' isn't added to the rap.psf file, so it
has to be checked out manually. Maybe this will be changed in the future and
the tutorial will be added to the next milestone help plugin. After that we
will provide it online as an infocenter installation.
Ensure that you have checked out the 'org.eclipse.rap.demo.feature' and not
the 'org.eclipse.rap.feature' which is used for the milestone build. We also
tried the anonymous account but the deployment_tutorial.html was there.
Maybe try the CVS Repository Exploring perspective to find it. If you are
still not able to check out the complete project, please give us some more
hints for troubleshooting, since maybe not only the tutorial is missing - so
putting the tutorial into the wiki would not be the solution.
Ciao
Frank
"Liat Golan" <liat_golan_herman@walla.co.il> schrieb im Newsbeitrag
news:5fa94cadedb2df1c780fa72e9e9e170a$1@www.eclipse.org...
> I tried to download the projects using the CVS, there was no
> "org.eclipse.rap.demo.feature" was imported.
> after manually adding a line with the "org.eclipse.rap.demo.feature" the
> project was added, but had no deployment_tutorial.html.
> Can you check the CVS, or add to wiki the explanations of how to deploy
> the demo to TOMCAT, using war.
> Liat
FUDForum. Page generated in 0.04245 seconds
