Home » Eclipse Projects » Eclipse Website » /eclipse.org-common/system/app.class.php
/eclipse.org-common/system/app.class.php [message #17060] Mon, 29 May 2006 16:36 Go to next message
I'm working on a project to make the platform RelEng website use the
pheonix style sheets and I need the specified php file :
I don't want to refer to the one on eclipse.org because I would like to test
it locally first. Where is this file located so I can copy it to my test
machine? Thankyou
Haytham Yassine
Re: /eclipse.org-common/system/app.class.php [message #17088 is a reply to message #17060] Tue, 30 May 2006 10:27 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
This file is in CVS:
http://dev.eclipse.org/viewcvs/index.cgi/www/eclipse.org-com mon/system/?cvsroot=Eclipse_Website
You should use a pserver CVS client and download the entire
/eclipse.org-common directory into the root folder of your website.
That way, your Phoenix webpages will work locally, and will work when
they're uploaded to www.eclipse.org.
http://www.eclipse.org/phoenix/docs/
D.
> machine? Thankyou
> Haytham Yassine
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: /eclipse.org-common/system/app.class.php [message #569236 is a reply to message #17060] Tue, 30 May 2006 10:27 Go to previous message
D.
> machine? Thankyou
> Haytham Yassine
Previous Topic:/eclipse.org-common/system/app.class.php
Next Topic:A few global changes
Current Time: Sat Nov 08 20:01:57 EST 2025
Powered by FUDForum. Page generated in 0.03906 seconds
