Split Screen [message #179985] |
Tue, 14 November 2006 09:18  |
Originally posted by: spurcell.ilevy.com
Just trying to use the IDE. I have a simple HTML document that I am
screwing around with. I was wondering, can the window I am viewing be
split? Also, the window tab shows "java" at the top.
What is the proper way to work with html, javascript files?
Re: Split Screen [message #180187 is a reply to message #180100] |
Tue, 14 November 2006 18:05  |
Originally posted by: eclipse4.rizzoweb.com
Scott K Purcell wrote:
> Thanks for the split screen, I have that now working. Works good.
> Also, I just installed the WTP packages. How do I use those if I have a
> html page on my screen? Major issue I have had is the editor not
> formatting well.
When you install WTP, it should associate the appropriate editors with
the various file extensions. So .html files should automatically open in
the proper editor.
If it is still opening in a plain text editor or the Java editor, try
closing the file and then choosing Open with... from the right-click
menu on that file.
Hope this helps,
Eric
FUDForum. Page generated in 1.08495 seconds
