Home » Language IDEs » C / C++ IDE (CDT) » Remote builder
Remote builder [message #179967] Fri, 17 November 2006 08:38 Go to next message
I have a problem in order to define a remote builder in managed make C
Project.
Is there any plugin wich allow to make it ?
I try to use "rsh" in the builder command line but it doesn't work very
well.
Thanks for your help.
Re: Remote builder [message #179983 is a reply to message #179967] Sat, 18 November 2006 02:38 Go to previous messageGo to next message
I have a shared workspace on another windows machine in our network and I
use psexec
( http://www.microsoft.com/technet/sysinternals/Security/PsExe c.mspx) to run
command on remote machine. This method may help you. We have our own build
system and I use standard make projects.
By the way, I usually do not work like that. I just wanted to try it and it
works. The only problem I came across is the console outputs. You may lose
console outputs. I do not know why. Running psexec from command line does
not have a problem.
Burak
"olivier receveur" <olivier.Receveur@jdsu.com> wrote in message
news:ejke14$opq$1@utils.eclipse.org...
>Project.
> well.
Re: Remote builder [message #180028 is a reply to message #179983] Mon, 20 November 2006 04:28 Go to previous messageGo to next message
Thanks for your answer Ali,
I'm using a Linux client machine and I want to compile on a Linux server,
so I cannot use your command.
At this time I use rsh in order to launch GCC on the server. Makefiles are
always managed on the client side and I think it's not the good way for
remote
compilation.
I want to know if some people have developped a plugin ( based on CDT
managed makefiles plugin ) where you can select the Host IP adress.
Olivier
Re: Remote builder [message #180366 is a reply to message #180028] Sat, 25 November 2006 02:26 Go to previous message
Well, I think this tool may be what you want.
http://sourceforge.net/projects/uniwin/
This tool works with SSH and SFTP, so make sure you have these tools
installed.
But this tool have some flaws with content assistant. If some one can help,
may be this plugin could be a perfect one to build remote project.
"olivier receveur" <olivier.receveur@jdsu.com>
??????:800cd6292af3df2404faf3ebc5f4feb5$1@www.eclipse.org...
> remote
> compilation.
> Olivier
Previous Topic:How to Replacing the Command Line Generator
Next Topic:.exe GNU on Windows
Current Time: Thu Nov 06 17:20:11 EST 2025
Powered by FUDForum. Page generated in 0.05974 seconds
