Problem with report engine2.1 [message #179845] |
Mon, 24 July 2006 16:04  |
Hi all,
Iam using birt report engine for report generation in my web
application. When i upgraded to birt2.1 pdf reports are not generating in
linux machine. In windows there are no problems. While generating the pdf
in linux class cast exception is coming with pdf layout manager. I placed
itext.jar file also in the plugins folder of report engine.
I want to know, is this problem with birt or i have missed some
configuration.
please help me. We are using jboss for web depoyment.
Bhaskar.
Re: Problem with report engine2.1 [message #179854 is a reply to message #179845] |
Mon, 24 July 2006 16:14  |
Hi, Here is the stacktrace my server console
01:44:55,502 INFO [STDOUT] java.lang.ClassCastException: [B
01:44:55,503 INFO [STDOUT] at
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory$ContentVisitor.visitForeign(PDFLayoutManagerFactory.ja va:188)
org.eclipse.birt.report.engine.content.impl.ForeignContent.a ccept(ForeignContent.java:52)
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory.createLayoutManager(PDFLayoutManagerFactory.java:79)
01:44:55,504 INFO [STDOUT] at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutChildNode(PDFBlockStackingLM.java:93)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:75)
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildren(PDFStackingLM.java:130)
01:44:55,505 INFO [STDOUT] at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:198)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:55)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:68)
01:44:55,506 INFO [STDOUT] at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:187)
com.rrs.corona.reportgenerator.RunReport.runreport(Unknown Source)
com.rrs.corona.reportgenerator.RunReport.run(Unknown Source)
com.rrs.corona.reportgenerator.ReportGenerator.createReport( Unknown Source)
01:44:55,507 INFO [STDOUT] at
com.rrs.corona.reportgenerator.ReportGenerator.generateRepor t(Unknown
Source)
com.rrs.corona.reportgenerator.Listener.onMessage(Unknown Source)
org.jboss.mq.SpyMessageConsumer.run(SpyMessageConsumer.java: 707)
01:44:55,507 INFO [STDOUT] at java.lang.Thread.run(Thread.java:595)
01:44:55,508 ERROR [RunReport] Exception in runreport method : Error
happened while running the report
01:44:55,509 ERROR [RunReport] Exception in run method:Error happened
Bhaskar
FUDForum. Page generated in 0.27341 seconds
