Home » Language IDEs » C / C++ IDE (CDT) » Terminating out of run leaves .exe file busy
Terminating out of run leaves .exe file busy [message #179533] Sat, 11 November 2006 14:35 Go to next message
Originally posted by: jcobban.magma.ca
Whenever I prematurely terminate a C++ program that I am executing under
"run" the .exe file is left busy. This means:
1) I cannot rebuild the C++ program because I get the messages:
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin /bin/ld: cannot
open output file Ged2Html.exe: Device or resource busy
collect2: ld returned 1 exit status
make: *** [Ged2Html.exe] Error 1
make: Target `all' not remade because of errors.
2) I cannot even delete the .exe.
The only workaround I know for this is to shut down and restart Win XP.
Is there any easier way to get around this?
I am running: Version: 3.0.2, Build id: 200503110845
Re: Terminating out of run leaves .exe file busy [message #179560 is a reply to message #179533] Mon, 13 November 2006 15:22 Go to previous message
Looks like the process is still running, even eclipse doesn't show it.
Have you tried to find your program in the task manager?
Maybe you can terminate it with the task manager if it is still running,
and relinking should work.
leo
btw: for a good task manager have a look at the process explorer from
sysinternals (www.sysinternals.com). Its free and very handy
Previous Topic:Debug existing C++ executable
Next Topic:standard vs managed make project and gdb differences
Current Time: Sun Aug 31 12:06:58 EDT 2025
Powered by FUDForum. Page generated in 0.03175 seconds
