Same version but .... [message #179517] |
Fri, 10 November 2006 21:29  |
Originally posted by: blastomick.gmail.com
I create project with Eclipse in my school
version: 3.2.0
Build id: M20060629-1905
When I try to load my project in my computer at home, I have a error who
say I don't have main class or I not have same version
But, I have a Main class and I have same version.
If I want use my project, I must create a new workSpace, new project and
new packages. Finaly, I must copy and paste my class in my other
workspace. And my project play normaly.
Do you have a explanation for my problem ?
P.S. Scuse me for my language, but I speak hardly in english, I am
Quebecer in Canada
Re: Same version but .... [message #179614 is a reply to message #179517] |
Sat, 11 November 2006 20:07   |
When you move stuff from an Eclipse installation on one machine to another,
move the ENTIRE project folder. The best way to do this would be to use
Subversion as a source code repository, perhaps at your school. Then you
can check in and out the entire project. If your school can set up a
Subversion repository, this is ideal. I use 5 different computers with
Eclipse to work on the same project, and this would be absolutely impossible
if I did not have a central source code repository.
By the way, Subversion is free, easy to install, etc. Your school should
use something like this simply to teach proper software engineering.
- Mike
On 11/10/06 7:29 PM, in article
ca3505ce1646dbdb50985653f7d40402$1@www.eclipse.org, "Bob"
<blastomick@gmail.com> wrote:
> Hello,
> version: 3.2.0
> Quebecer in Canada
FUDForum. Page generated in 0.07606 seconds
