Home » Archived » BIRT » PLEASE HELP--How Are You Supposed to Pass Data Set Input Parameters?
PLEASE HELP--How Are You Supposed to Pass Data Set Input Parameters? [message #179456] |
Fri, 21 July 2006 12:16  |
Folks,
Going through past forum entries, I have seen many developers asking
the same question and never is there an answer--how do you pass a
parameter to a query?
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Claim Data Set" id="6">
<property name="dataSource">Data Source</property>
<list-property name="parameters">
<structure>
<property name="name">WHERE_CLAUSE</property>
<property name="dataType">string</property>
<property name="position">1</property>
<property name="defaultValue">"1"</property>
<property name="isOptional">false</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<property name="queryText">
SELECT *
FROM CLAIM
WHERE '1' = ?
SOLVED! --How Are You Supposed to Pass Data Set Input Parameters? [message #179538 is a reply to message #179456] |
Fri, 21 July 2006 20:01  |
Folks,
Because of the help of Jason, I have been able to solve this. And I
would never have figured it out by myself. What I was trying to accomplish
was to pass in the contents of the where clause, which had been been
created dynamically at run time. Here's how I did it.
REPORT DESIGN FILE:
Important aspects of this:
1.) The WHERE_CLAUSE parameter is set up to be appended to the
query's
where clause. Notice the default is designed to produce no output so I
will notice if anything goes astray.
2.) The setting for the method is the critical part. You see that it
takes the property called "queryText" (which is defined right after it)
and
appends my parameter WHERE_CLAUSE to it and then it replaces the
original
with the version I added the WHERE CLAUSE to.
<method name="beforeOpen"><![CDATA[this.queryText = this.queryText + " " +
params["WHERE_CLAUSE"];]]></method>
3.) Finally, notice the end of my query. It ends in the statement
WHERE
I do that so the query is ready to accept the clause I've built in Java.
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.0.1 Build
<20060222-1204></property>
<property name="units">in</property>
<text-property name="displayName">Worksheet Report</text-property>
<parameters>
<scalar-parameter name="WHERE_CLAUSE" id="7">
<property name="valueType">static</property>
<property name="defaultValue">1 = 0</property>
<property name="controlType">text-box</property>
<property name="format">Unformatted</property>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="4">
<property
name="odaDriverClass">com.microsoft.sqlserver.jdbc.SQLServerDriver </property>
<property
name="odaURL">jdbc:sqlserver://localhost:1433;databaseName=FREYA_DB</property>
<property name="odaUser">FREYA</property>
<encrypted-property
name="odaPassword">bWlkZ2FyZDE=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
this.queryText + " " + params["WHERE_CLAUSE"];]]></method>
SELECT
CLAIM.CLAIM_EID
FROM
CLAIM
WHERE
</property>
</oda-data-set>
Finally, for the sake of completeness, I will give you the method that
builds the query. The portion you really need to focus on here is any one
of the ones that builds a WHERE CLAUSE:
public void populateParameters2( HashMap<String, Object> pOut, Object[]
pIn )
StringBuffer where = new StringBuffer();
where.append( " \n CLAIM1.DISCRIMINATOR = 'PRO' " );
where.append( populateStartAndEndClaimIID( pOut, pIn[ 1 ],
pIn[ 2 ] ) );
where.append( populateStartAndEndSystemEntryDate( pOut, pIn[ 3 ],
pIn[ 4 ] ) );
where.append( populateStartAndEndServiceStartDate( pOut, pIn[ 5 ],
pIn[ 6 ] ) );
where.append( populateStartAndEndBatchEID( pOut, pIn[ 7 ],
pIn[ 8 ] ) );
where.append( populateStartAndEndPractitionerEID( pOut, pIn[ 9 ],
pIn[ 10 ] ) );
where.append( populateStartAndEndMedicalRecordNumber( pOut, pIn[ 11 ],
pIn[ 12 ] ) );
where.append( populateFlags( pOut, pIn[ 17 ],
pIn[ 18 ], pIn[ 19 ], pIn[ 20 ] ) );
where.append( populateEnvironment( pOut, pIn[ 21 ],
pIn[ 22 ] ) );
where.append( populateAdditionalData( pOut, pIn[ 23 ],
pIn[ 24 ], pIn[ 25 ] ) );
where.append( populateAccountsList( pOut, pIn ) );
where.append( populatePlansList( pOut, pIn ) );
where.append( populateFlagsList( pOut, pIn ) );
pOut.put( "WHERE_CLAUSE", where.toString() );
COMPLETE CLASS
package com.ingenix.freya.web.components.reporting;
import java.io.ByteArrayOutputStream;
import java.io.InputStream;
import java.util.Date;
import java.util.HashMap;
import java.util.Iterator;
import org.apache.tapestry.AbstractComponent;
import org.apache.tapestry.IMarkupWriter;
import org.apache.tapestry.IRequestCycle;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.ReportEngine;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SlotHandle;
import com.ingenix.freya.api.configuration.ConfigurationService;
import com.ingenix.freya.api.configuration.ConfigurationServiceAcce ssor;
import com.ingenix.freya.web.reporting.PeReportCriteria;
import com.ingenix.freya.web.reporting.ReportingUtil;
import com.ingenix.freya.web.util.CipherUtilityWeb;
public abstract class PeReportRenderer extends AbstractComponent
private String mEditErrorType = "";
public void setEditErrorType( String pEditErrorType )
mEditErrorType = pEditErrorType;
public String getEditErrorType()
return mEditErrorType;
public static final String cEDIT_ERROR_TYPE_CLAIM = "CLAIM";
public static final String cEDIT_ERROR_TYPE_PATIENT = "PATIENT";
public static final String cEDIT_ERROR_TYPE_PROVIDER = "PROVIDER";
public static final String cEDIT_ERROR_TYPE_PLAN = "PLAN";
public static final String cEDIT_ERROR_TYPE_ACCOUNT = "ACCOUNT";
public abstract boolean[] getAccountSelection();
public abstract void setAccountSelection( boolean[] pAccountSelection );
public abstract boolean[] getPlanSelection();
public abstract void setPlanSelection( boolean[] pPlanSelection );
public abstract boolean[] getFlagSelection();
public abstract void setFlagSelection( boolean[] pFlagSelection );
protected void renderComponent(IMarkupWriter pWriter, IRequestCycle
pCycle)
pWriter.begin("p");
getHTMLReport(pWriter, pCycle.getListenerParameters());
pWriter.end("p");
private void getHTMLReport(IMarkupWriter pWriter, Object[] pParameters)
ReportEngine engine = ReportingUtil.getEngine();
// Run reports, etc.
try
HashMap<String, Object> parameters = new HashMap<String, Object>();
setOutgoingParameters( parameters, pParameters );
IReportRunnable design = getReportSpecification( engine,
(String)pParameters[ 0 ] );
// Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
// Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
// renderContext.setImageDirectory("image");
HashMap<String, Object> contextMap = new HashMap<String, Object>();
contextMap.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
task.setAppContext(contextMap);
task.setParameterValues(parameters);
populateDatabaseConnectionParameters( design );
// create output stream
ByteArrayOutputStream out = new ByteArrayOutputStream(2048);
// Set rendering options - such as file or stream output,
// output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputStream(out);
options.setOutputFormat("html");
task.setRenderOption(options);
// UTF-8
task.run();
pWriter.printRaw( out.toString( "UTF-8" ) );
//printReport(pWriter, engine, report);
catch (Exception e1)
e1.printStackTrace();
// Shut down the engine.
if (engine != null)
engine.destroy();
private IReportRunnable getReportSpecification( ReportEngine pEngine,
String pFileName ) throws Exception
InputStream stream =
PeReportRenderer.class.getClassLoader().getResourceAsStream( pFileName );
IReportRunnable design = pEngine.openReportDesign( stream );
return design;
/** Because each report has its own set of particulars that must be set,
this method just redirects to the
* particular methods that are designed for that report.*/
private void setOutgoingParameters( HashMap<String,
Object>pOutgoingParameters, Object[] pIncomingParameters )
// First, determine which report this is.
String reportParm = (String) pIncomingParameters[ 0 ];
if( reportParm == null )
return;
int reportNumber = -1;
String[] reportPaths = PeReportCriteria.cReportPaths;
for( int i = 0; i < reportPaths.length; i++ )
if( reportParm.equals( reportPaths[ i ] ) )
reportNumber = i;
break;
switch( reportNumber )
case -1:
break;
case 0:
//populateParameters0( pOutgoingParameters, pIncomingParameters
); // This is actually redirected to other Edit Error reports.
break;
case 1:
populateParameters1( pOutgoingParameters, pIncomingParameters );
break;
case 2:
populateParameters2( pOutgoingParameters, pIncomingParameters );
break;
case 3:
populateParameters3( pOutgoingParameters, pIncomingParameters );
break;
case 4:
populateParameters4( pOutgoingParameters, pIncomingParameters );
break;
case 5:
populateParameters5( pOutgoingParameters, pIncomingParameters );
break;
case 6:
populateParameters6( pOutgoingParameters, pIncomingParameters );
break;
case 7:
populateParameters7( pOutgoingParameters, pIncomingParameters );
break;
case 8:
populateParameters8( pOutgoingParameters, pIncomingParameters );
break;
case 9:
populateParameters9( pOutgoingParameters, pIncomingParameters );
break;
case 10:
populateParameters10( pOutgoingParameters, pIncomingParameters );
break;
case 11:
populateParameters11( pOutgoingParameters, pIncomingParameters );
break;
case 12:
populateParameters12( pOutgoingParameters, pIncomingParameters );
break;
case 13:
populateParameters13( pOutgoingParameters, pIncomingParameters );
break;
case 14:
populateParameters14( pOutgoingParameters, pIncomingParameters );
break;
case 15:
populateParameters15( pOutgoingParameters, pIncomingParameters );
break;
case 16:
populateParameters16( pOutgoingParameters, pIncomingParameters );
break;
/** This is for the Worksheet_Report.rptdesign */
public void populateParameters1( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
/** The following logic is necessary in case we arrived here via the
Claim Edit Screen, which only
* supplies parameters for parms 0, 1, 2 */
if( pIn.length > 3 )
], pIn[ 4 ] ) );
], pIn[ 6 ] ) );
], pIn[ 8 ] ) );
], pIn[ 10 ] ) );
], pIn[ 12 ] ) );
], pIn[ 18 ], pIn[ 19 ], pIn[ 20 ] ) );
], pIn[ 22 ] ) );
], pIn[ 24 ], pIn[ 25 ] ) );
/** This is the Edit Summary Report, Edit_Summary_Report.rptdesign */
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 22 ] ) );
/** This is the Savings Summary Report, Savings_Summary_Report.rptdesign
public void populateParameters3( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 22 ] ) );
/** This is the Diagnosis Drill Down Report,
Dx_Drill_Down_Report.rptdesign */
public void populateParameters4( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
where.append( populateStartAndEndMedicalRecordNumber( pOut, pIn[ 11],
pIn[ 12 ] ) );
where.append( populateStartAndEndDiagnosisCode( pOut, pIn[ 13],
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Diagnosis Frequency Report,
Diagnosis_Frequency_Report.rptdesign */
public void populateParameters5( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Frequency by Diagnosis by Procedure Report,
Freq_by_Diag_Proc_Report.rptdesign */
public void populateParameters6( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
where.append( populateStartAndEndProcedureCode( pOut, pIn[ 15],
pIn[ 16 ] ) );
pIn[ 22 ] ) );
/** This is the Frequency by Procedure by Diagnosis Report,
Freq_by_Proc_Diag_Report.rptdesign */
public void populateParameters7( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 16 ] ) );
pIn[ 22 ] ) );
/** This is the Px_Drill_Down_Report.rptdesign */
public void populateParameters8( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
where.append( populateStartAndEndProcedureCode( pOut, pIn[ 13],
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Procedure_Frequency_Report.rptdesign */
public void populateParameters9( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Proc_Frequency_by_Proc.rptdesign */
public void populateParameters10( HashMap<String, Object> pOut, Object[]
pIn )
where.append( "\n AND CLAIM_LINE1.ADJUSTED_PROCEDURE_CODE <>
CLAIM_LINE2.ADJUSTED_PROCEDURE_CODE " );
where.append( "\n AND CLAIM_LINE1.PRACTITIONER_IID IS NOT NULL " );
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Database Customization Report,
KB_Customization_Report.rptdesign */
public void populateParameters11( HashMap<String, Object> pOut, Object[]
pIn )
where.append( " \n AUDIT_LOG.COMPONENT_NAME = 'DIAGNOSIS_CODE' " );
where.append( populateStartAndEndUserIID( pOut, pIn[ 1 ],
pIn[ 2 ] ) );
where.append( populateStartAndEndAuditDate( pOut, pIn[ 3 ],
pIn[ 4 ] ) );
where.append( populateStartAndEndRulesetName( pOut, pIn[ 5 ],
pIn[ 6 ] ) );
where.append( populateStartAndEndEnterpriseName( pOut, pIn[ 7 ],
pIn[ 8 ] ) );
pIn[ 22 ] ) );
/** This is the EditError_Claim_Report.rptdesign */
public void populateParameters12( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the EditError_Patient_Report.rptdesign */
public void populateParameters13( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the EditError_Provider_Report.rptdesign */
public void populateParameters14( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 14 ] ) );
pIn[ 22 ] ) );
/** This is the Edit Error Plan Report, EditError_Plan_Report.rptdesign
public void populateParameters15( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 22 ] ) );
/** This is for the EditError_Account_Report.rptdesign */
public void populateParameters16( HashMap<String, Object> pOut, Object[]
pIn )
pIn[ 2 ] ) );
pIn[ 4 ] ) );
pIn[ 6 ] ) );
pIn[ 8 ] ) );
pIn[ 10 ] ) );
pIn[ 12 ] ) );
pIn[ 22 ] ) );
private String populateStartAndEndClaimIID( HashMap<String, Object>
pOut, Object pStart, Object pEnd )
String start = (String) pStart;
String end = (String) pEnd;
if( start == null && end == null )
else if( start != null && end == null )
where.append( "\n" );
where.append( " AND \n " );
where.append( " (" );
where.append( " (CLAIM1.CLAIM_EID = '" + start + "')" );
where.append( " )" );
else if( start != null && end != null )
where.append( " AND (" );
where.append( " (CLAIM1.CLAIM_EID >= '" + start + "') AND
(CLAIM1.CLAIM_EID <= '" + end + "') " );
return where.toString();
private String populateStartAndEndSystemEntryDate( HashMap<String,
Object> pOut, Object pStart, Object pEnd )
Date start = (Date) pStart;
Date end = (Date) pEnd;
where.append( " AND (CLAIM1.SYSTEM_ENTRY_DATE = '" +
start.toString() + "' )" );
where.append( " AND (CLAIM1.SYSTEM_ENTRY_DATE >= '" +
start.toString() + "' ) AND (CLAIM1.SYSTEM_ENTRY_DATE <= '" +
end.toString() + "' ) " );
private String populateStartAndEndServiceStartDate( HashMap<String,
where.append( " AND (CLAIM_LINE.SERVICE_START_DATE = '" +
where.append( " AND (CLAIM_LINE.SERVICE_START_DATE >= '" +
start.toString() + "' ) AND (CLAIM_LINE.SERVICE_START_DATE <= '" +
private String populateStartAndEndAuditDate( HashMap<String, Object>
where.append( " AND (AUDIT_LOG.AUDIT_DATE = '" + start.toString() +
where.append( " AND (AUDIT_LOG.AUDIT_DATE >= '" + start.toString() +
"' ) AND (AUDIT_LOG.AUDIT_DATE <= '" + end.toString() + "' ) " );
private String populateStartAndEndBatchEID( HashMap<String, Object>
where.append( " AND (CLAIM1.BATCH_EID = '" + start + "')" );
where.append( " AND (CLAIM1.BATCH_EID >= '" + start + "') AND
(CLAIM1.BATCH_EID <= '" + end + "') " );
private String populateStartAndEndPractitionerEID( HashMap<String,
where.append( " AND (PRACTITIONER.PRACTITIONER_EID = '" + start +
where.append( " AND (PRACTITIONER.PRACTITIONER_EID >= '" + start +
"') AND (PRACTITIONER.PRACTITIONER_EID <= '" + end + "') " );
private String populateStartAndEndMedicalRecordNumber( HashMap<String,
where.append( " AND (PATIENT.MEDICAL_RECORD_NUMBER = '" + start +
where.append( " AND (PATIENT.MEDICAL_RECORD_NUMBER >= '" + start +
"') AND (PATIENT.MEDICAL_RECORD_NUMBER <= '" + end + "') " );
private String populateStartAndEndUserIID( HashMap<String, Object> pOut,
where.append( " AND (PERMISSIBLE_USER.USERNAME = '" + start + "')" );
where.append( " AND (PERMISSIBLE_USER.USERNAME >= '" + start + "')
AND (PERMISSIBLE_USER.USERNAME <= '" + end + "') " );
private String populateStartAndEndRulesetName( HashMap<String, Object>
where.append( " AND (FREYA_RULESET.NAME = '" + start + "')" );
where.append( " AND (FREYA_RULESET.NAME >= '" + start + "') AND
(FREYA_RULESET.NAME <= '" + end + "') " );
private String populateStartAndEndEnterpriseName( HashMap<String,
where.append( " AND (ENTERPRISE.NAME = '" + start + "')" );
where.append( " AND (ENTERPRISE.NAME >= '" + start + "') AND
(ENTERPRISE.NAME <= '" + end + "') " );
private String populateStartAndEndDiagnosisCode( HashMap<String, Object>
where.append( " AND (CLAIM_LINE_DIAGNOSIS.DIAGNOSIS_CODE = '" +
start + "')" );
where.append( " AND (CLAIM_LINE_DIAGNOSIS.DIAGNOSIS_CODE >= '" +
start + "') AND (CLAIM_LINE_DIAGNOSIS.DIAGNOSIS_CODE <= '" + end + "') " );
private String populateStartAndEndProcedureCode( HashMap<String, Object>
where.append( " AND (CLAIM_LINE.ADJUSTED_PROCEDURE_CODE = '" + start
where.append( " AND (CLAIM_LINE.ADJUSTED_PROCEDURE_CODE >= '" +
start + "') AND (CLAIM_LINE.ADJUSTED_PROCEDURE_CODE <= '" + end + "') " );
private String populateFlags( HashMap<String, Object> pOut, Object
pProfile, Object pDeny, Object pReview, Object pInterim )
String p = (String) pProfile;
String d = (String) pDeny;
String r = (String) pReview;
int pp = p.indexOf( "true" );
int dd = d.indexOf( "true" );
int rr = r.indexOf( "true" );
boolean needOR = false;
if( pp > -1 || dd > -1 || rr > -1 )
where.append( " AND " );
where.append( " 1 = 0 " );
where.append( " OR " );
if( pp > -1 )
where.append( " (CLAIM_LINE_EDIT.ACTION = 'P') " );
needOR = true;
if( dd > -1 )
if( needOR )
needOR = false;
where.append( " (CLAIM_LINE_EDIT.ACTION = 'R') " );
needOR = true;
if( rr > -1 )
if( needOR )
needOR = false;
where.append( " (CLAIM_LINE_EDIT.ACTION = 'D') " );
private String populateEnvironment( HashMap<String, Object> pOut, Object
pLive, Object pTest )
String l = (String) pLive;
String t = (String) pTest;
int ll = l.indexOf( "true" );
int tt = t.indexOf( "true" );
if( ll > -1 || tt > -1 )
where.append( "AND " );
where.append( "(" );
if( ll > -1 )
where.append( " (CLAIM1.CONTEXT = 1) " );
if( tt > -1 )
where.append( " (CLAIM1.CONTEXT = 0) " );
where.append( ")" );
private String populateAdditionalData( HashMap<String, Object> pOut,
Object pAccounts, Object pPlans, Object pFlags )
private void populateDatabaseConnectionParameters( IReportRunnable
pDesign )
ConfigurationService cs = ConfigurationServiceAccessor.getService();
String dbUrl = cs.getValue( "/t360/framework/reporting",
"reporting.db.url", "" );
String dbUser = cs.getValue( "/t360/framework/reporting",
"reporting.db.userid", "" );
String dbPassword = cs.getValue( "/t360/framework/reporting",
"reporting.db.password", "" );
/** The password comes to us encrypted from the database. This will
decrypt it. */
dbPassword = CipherUtilityWeb.decrypt( dbPassword );
DesignElementHandle deh = pDesign.getDesignHandle();
SlotHandle slotHandle = deh.getSlot(
ReportDesignHandle.DATA_SOURCE_SLOT );
Iterator iter = slotHandle.iterator();
try
while( iter.hasNext() )
Object obj = iter.next();
OdaDataSourceHandle odaSrcHdl = (OdaDataSourceHandle) obj;
Iterator propIter = odaSrcHdl.getPropertyIterator();
while( propIter.hasNext() )
PropertyHandle propHdl = (PropertyHandle) propIter.next();
if( propHdl.getPropertyDefn().getName().equalsIgnoreCase(
"odaURL" ) )
propHdl.setStringValue( dbUrl );
else if( propHdl.getPropertyDefn().getName().equalsIgnoreCase(
"odaUser" ) )
propHdl.setStringValue( dbUser );
"odaPassword" ) )
propHdl.setStringValue( dbPassword );
catch( Exception e )
e.printStackTrace();
public String populateAccountsList( HashMap<String, Object> pOut,
Object[] pIn )
StringBuffer out = new StringBuffer();
out.append( "AND " );
out.append( "\n" );
out.append( "CLAIM1.ACCOUNT_EID IN " );
out.append( "\n" );
out.append( "( " );
out.append( "\n" );
boolean foundAccount = false;
boolean needComma = false;
for( int i = 0; i < pIn.length; i++ )
Object slot = pIn[ i ];
if( slot instanceof String )
String slt = (String) slot;
int accountIndex = slt.indexOf( PeReportCriteria.ACCOUNT_PARMS );
// start
int planIndex = slt.indexOf( PeReportCriteria.PLAN_PARMS );
// end
// This means don't filter at all by this term.
if( slt.equals( PeReportCriteria.ALL_BRACKETED ) || slt.equals(
PeReportCriteria.NO_RECORDS ) )
return "";
if( planIndex > -1 )
out.append( "\n" );
out.append( ")" );
out.append( "\n" );
break;
if( needComma )
out.append( ", " );
needComma = false;
if( foundAccount )
out.append( "'" + slt + "'" );
needComma = true;
if( accountIndex > -1 )
foundAccount = true;
return out.toString();
public String populatePlansList( HashMap<String, Object> pOut, Object[]
pIn )
out.append( "\n" );
out.append( "CLAIM1.PLAN_EID IN " );
out.append( "\n" );
out.append( "( " );
out.append( "\n" );
boolean foundPlan = false;
int planIndex = slt.indexOf( PeReportCriteria.PLAN_PARMS ); //
start
int flagIndex = slt.indexOf( PeReportCriteria.FLAG_PARMS ); //
end
Pe
Current Time: Tue Jul 15 05:10:33 EDT 2025
Powered by FUDForum. Page generated in 0.09878 seconds
