Home » Eclipse Projects » Eclipse Platform » adding plug-in to rcp app. prevents it from starting
adding plug-in to rcp app. prevents it from starting [message #179450] Tue, 13 January 2004 17:29 Go to next message
Originally posted by: olivier.crameri.netoxygen_nospam.ch
this message is to help people currently looking to fix the same I was
trying to fix for now about 2 hours :(
I'm currently writing an application based on Eclipse RCP.
I wanted to use GEF in my app, so I added the GEF plug-ins in my
<requires> section of plugin.xml, but this prevented my application to
start. As you'll understand the real problem is not GEF specific, and
could potentially happen with any other eclipse plugin.
The error message in .log was: !MESSAGE Unable to locate application
extension:
As I saw on this newsgroup, this error message actually means that a
plug-in is missing.
Actually, plugins where missing, and those plug-ins where needed because
they were dependencies of dependencies of GEF ...
so I had to open every plugin.xml of every plugin listed in the
<requires> tag of GEF's plugin.xml to find missing plugins to import...
More time-effective solutions are welcome !
Thanks in advance,
Olivier
Re: adding plug-in to rcp app. prevents it from starting [message #179467 is a reply to message #179450] Tue, 13 January 2004 17:52 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Right click on your RCP project and select PDE Tools > Open Dependencies.
I've also entered an enhancement request for something better - you can
cc/vote for:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49591
Also, M7 will include a nicer error message when a plug-in is missing.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Olivier Crameri" <olivier.crameri@netoxygen_nospam.ch> wrote in message
news:20040113233055061+0100@news.eclipse.org...
> Thanks in advance,
> Olivier
Re: adding plug-in to rcp app. prevents it from starting [message #179793 is a reply to message #179467] Wed, 14 January 2004 07:22 Go to previous message
Thanks, that's really better !
Olivier
Previous Topic:Language Pack: how do I change the current language?
Next Topic:Sysdeo Tomcat Launcher: does not use actual code
Current Time: Fri Jul 11 20:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
