Home » Modeling » GMF (Graphical Modeling Framework) » Remove Scroll Bars from Compartment
Remove Scroll Bars from Compartment [message #179330] Thu, 27 March 2008 05:38 Go to next message
Originally posted by: john.blutarsky.hotmail.com
Hello everyone,
Is it possible to remove (turn off) a compartments scroll bar?
Thank you,
John
Re: Remove Scroll Bars from Compartment [message #183223 is a reply to message #179330] Wed, 16 April 2008 06:01 Go to previous messageGo to next message
John Bluto wrote:
> Hello everyone,
> Thank you,
> John
John,
I'd like to do the same thing. Are you still waiting for an answer , or
did you find a way to achieve what you want ?
Matthieu
Re: Remove Scroll Bars from Compartment [message #183470 is a reply to message #179330] Thu, 17 April 2008 12:42 Go to previous messageGo to next message
In the Xxx_CompartmentEditPart, alter the createFigure method.
ResizableCompartmentFigure contains an AnimatableScrollPane on index 1.
You can set the scrollbars to null here.
Lucian
Re: Remove Scroll Bars from Compartment [message #183537 is a reply to message #183470] Fri, 18 April 2008 03:16 Go to previous message
Ok, I found the ScrollBar on the ResizableCompartmentFigure.
Thank you very much !
Matthieu
Previous Topic:Avoid the deletion of a compartment
Next Topic:Importing a different Ecore model into an editor
Current Time: Sun Aug 31 16:35:37 EDT 2025
Powered by FUDForum. Page generated in 0.03545 seconds
