Home » Language IDEs » C / C++ IDE (CDT) » "source not found in debug" - but debugger works ok
"source not found in debug" - but debugger works ok [message #179233] Fri, 03 November 2006 16:14 Go to next message
Originally posted by: lgrigely.EO.kollmorgen.com
i now have this problem after using CDT fine for past 6 months
- i think it occurred after compiling C++ for first time (after a few miles
of java and C code development...)
- running on Win XP
- re-installed Cygwin and Eclipse 3.2.1
symptoms =
1 ) compile and debugger appear to work, example here was a small "c"
program (not c++)
2) during debug, breakpoint line numbers display properly in the debug
window, i.e.
" 1 main() at \cygdrive\c\dev_root\ws1\Project_name\APPNAME_MAIN.c:185
0x00401170 "
3) there are no spaces in project path (saw a bug reported to cause this)
4) selected full path with "Edit Source Lookup Path" button - no success
5) simply refuses to open source file - even though it has full reference
to proper file name
any comments?
Re: "source not found in debug" - fixed [message #179242 is a reply to message #179233] Fri, 03 November 2006 16:38 Go to previous messageGo to next message
My impatience.....
see previous post on 30 Aug by Don Porges
need to map cygwin to drive path
> Preferences->C/C++->Debug->Common Source Lookup Pathand add a mapping from
> C: to /cygdrive/c .
thank you Don
Re: "source not found in debug" - fixed [message #179283 is a reply to message #179242] Sun, 05 November 2006 14:52 Go to previous message
Originally posted by: lemaypNO_SPAM.videotron.ca
Larry,
thanks for replying your solution once you fixed it as this is the exact
same situation that I was trying to resolve in my previous message on 18/10.
I just tried what you have posted here and now my debugger is able to
properly show the file source. As you, I was using CDT and the debugger for
over 6 months without any problem, until I reinstalled cywing elsewhere..
thanks,
- Pierre
"Larry G" <lgrigely@EO.kollmorgen.com> wrote in message
news:eigcs2$dt3$1@utils.eclipse.org...
> My impatience.....
>> from C: to /cygdrive/c .
> thank you Don
Previous Topic:Linker doesn't add space between -l and path
Next Topic:Started to have problem with CDT since reinstalled/relocated cygwin
Current Time: Mon Nov 17 07:33:37 EST 2025
Powered by FUDForum. Page generated in 0.41679 seconds
