Home » Language IDEs » C / C++ IDE (CDT) » Error when attempting to debug under Solaris
Error when attempting to debug under Solaris [message #179183] Thu, 02 November 2006 16:33
Hello All,
I'm trying to debug a small program under Solaris 10. When I try to bring
up the debugger by clicking on the debug icon, I get the following error:
An error has occurred. See error log for more details.
This is what the error log says:
Message: Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
java.lang.ArrayIndexOutOfBoundsException: 0
org.eclipse.cdt.debug.mi.internal.ui.StandardGDBDebuggerPage .initializeFrom(StandardGDBDebuggerPage.java:199)
org.eclipse.cdt.launch.internal.ui.AbstractCDebuggerTab.hand leDebuggerChanged(AbstractCDebuggerTab.java:140)
org.eclipse.cdt.launch.internal.ui.AbstractCDebuggerTab.upda teComboFromSelection(AbstractCDebuggerTab.java:312)
org.eclipse.cdt.launch.ui.CDebuggerTab.updateComboFromSelect ion(CDebuggerTab.java:203)
org.eclipse.cdt.launch.internal.ui.AbstractCDebuggerTab.load DebuggerCombo(AbstractCDebuggerTab.java:289)
org.eclipse.cdt.launch.ui.CDebuggerTab.loadDebuggerComboBox( CDebuggerTab.java:199)
org.eclipse.cdt.launch.ui.CDebuggerTab.initializeFrom(CDebug gerTab.java:231)
org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.ini tializeFrom(AbstractLaunchConfigurationTabGroup.java:86)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:655)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$6.run(LaunchConfigurationTabGroupVi ewer.java:548)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:565)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:529)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:928)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$4.selectionChanged(LaunchConfigurationsDia log.java:547)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:839)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:837)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1578)
at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:38 4)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.doInitialTreeSelection(LaunchConfiguration sDialog.java:587)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.initializeContent(LaunchConfigurationsDial og.java:1034)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.createContents(LaunchConfigurationsDialog. java:434)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.create(LaunchConfigurationsDialog.java:363 )
at org.eclipse.jface.window.Window.open(Window.java:785)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1086)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 3)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:387)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:329)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3166)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2842)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Here is my system info:
eclipse.buildId=M20060921-0945
java.version=1.4.2_12
BootLoader constants: OS=solaris, ARCH=sparc, WS=gtk, NL=en
Command-line arguments: -os solaris -ws gtk -arch sparc
Previous Topic:using/configuring the C compare viewer
Next Topic:Change the output folder for a CDT project
Current Time: Sat Oct 11 18:01:02 EDT 2025
Powered by FUDForum. Page generated in 0.05872 seconds
