Home » Modeling » Epsilon » Accessing subpackages in EVL
| Accessing subpackages in EVL [message #16904] |
Thu, 30 April 2009 07:57  |
Hello!
Another simple question about EVL. What is a syntax to access subpackage's
classes?
The syntax subPackageOfPackageA::subClass seems not to work in the .evl
file which is associated with PackageA.
Also I've found out that there's an ! operation in EOL which gives access
to metamodel's elements like:
ModelName!packageName::className
but it's not clear how to use it in EVL, where do I get the ModelName?
| Re: Accessing subpackages in EVL [message #17165 is a reply to message #17079] |
Thu, 30 April 2009 11:50   |
Hi Yuri,
This makes much sense indeed. I'm working on a patch for this now and
will hopefully release a new interim version later on today.
Dimitris
Yuri G wrote:
> I see, Dimitris, thanks for reply. Let me illustrate my case.
> The metamodel is split into two .ecore files:
> <CoreMM.ecore>
> CorePackage : EPackage
> CoreSubPackage : EPackage
> CoreClass : EClass (contains ClassX elements)
> ClassX : EClass (contains references to ClassY)
> ClassY : EClass (abstract)
> <ChildMM.ecore>
> ChildPackage : EPackage
> ChildSubPackage : EPackage
> ChildOfY : EClass -> ClassY
> Developed GMF editor for CoreClass can draw diagram nodes for ClassX and
> ChildOfY meta-elements.
> I've created a .evl constraint binded to CoreSubPackage namespaceURI:
> context ClassX {...}
> Now I'd like to implement a quick-fix in this constraint which would
> create a ChildOfY node in my diagram and add a reference to it into the
> validated ClassX if needed. But there's no way I can get to ChildOfY
> EClass to create its instance.
> ChildPackage has the same name as CorePackage, that's why I initially
> tried to access it from my .evl file. But, apparently, I can't access
> this package, because it has another namespaceURI than CorePackage and
> resides in another .ecore file.
> I also think about creating an Epsilon wizard instead of this quick-fix.
> But I haven't looked into EWL much, so I'm not sure if it's even possible.
| Re: Accessing subpackages in EVL [message #17194 is a reply to message #17165] |
Thu, 30 April 2009 11:53   |
In the meantime could you please open a new enhancement request about
this in the bugzilla so that we can keep track of this?
Dimitris
Dimitris Kolovos wrote:
> Hi Yuri,
> Cheers,
> Dimitris
>> <CoreMM.ecore>
>> <ChildMM.ecore>
>> and ChildOfY meta-elements.
>> the validated ClassX if needed. But there's no way I can get to
>> ChildOfY EClass to create its instance.
>> quick-fix. But I haven't looked into EWL much, so I'm not sure if it's
>> even possible.
| Re: Accessing subpackages in EVL [message #17249 is a reply to message #17194] |
Thu, 30 April 2009 12:24   |
Sure, done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274544
> Cheers,
> Dimitris
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> <CoreMM.ecore>
>>> <ChildMM.ecore>
>>> even possible.
| Re: Accessing subpackages in EVL [message #17276 is a reply to message #17249] |
Thu, 30 April 2009 12:55   |
Thanks Yuri. I've just uploaded a new interim version
(0.8.5.200904301737) under
http://download.eclipse.org/modeling/gmt/epsilon/interim/. To create a
new ChildOfY you should now add the following line of code before:
_Model.addNamespaceUri('uri-of-ChildPackage');
var childOfY := new ChildPackage::ChildSubPackage::ChildOfY;
(_Model is the implicit name of the currently validated model)
Please let me know if it works for you. If not, I'll give it another go
tomorrow with a clearer mind.
Dimitris
Yuri G wrote:
> Sure, done:
>> Cheers,
>> Dimitris
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>>> <CoreMM.ecore>
>>>> <ChildMM.ecore>
>>>> initially tried to access it from my .evl file. But, apparently, I
>>>> can't access this package, because it has another namespaceURI than
>>>> CorePackage and resides in another .ecore file.
>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #17353 is a reply to message #17276] |
Fri, 01 May 2009 03:46   |
Hello, Dimitris!
I've just tried the patch, seems not to work with runtime error 'Method
'addNamespaceUri' not found'.
Also I did a search for 'addNamespaceUri' string in the source codes of
the downloaded interim plug-ins and it found nothing.
> Cheers,
> Dimitris
> Yuri G wrote:
>> Sure, done:
>>> Cheers,
>>> Dimitris
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> <CoreMM.ecore>
>>>>> <ChildMM.ecore>
>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #17374 is a reply to message #17353] |
Fri, 01 May 2009 04:53   |
Hi Yuri,
Sorry about that. The method is actually called addMetamodelUri instead
of addNamespaceUri.
Dimitris
Yuri G wrote:
> Hello, Dimitris!
>> go tomorrow with a clearer mind.
>> Cheers,
>> Dimitris
>> Yuri G wrote:
>>> Sure, done:
>>>> about this in the bugzilla so that we can keep track of this?
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Yuri,
>>>>> and will hopefully release a new interim version later on today.
>>>>> Cheers,
>>>>> Dimitris
>>>>>> <CoreMM.ecore>
>>>>>> <ChildMM.ecore>
>>>>>> ClassX and ChildOfY meta-elements.
>>>>>> would create a ChildOfY node in my diagram and add a reference to
>>>>>> it into the validated ClassX if needed. But there's no way I can
>>>>>> get to ChildOfY EClass to create its instance.
>>>>>> than CorePackage and resides in another .ecore file.
>>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #17842 is a reply to message #17374] |
Fri, 01 May 2009 08:36   |
Hi, Dimitris. Thank you for reply!
addMetamodelUri almost works. Now my constraint can see the classes from
the added EPackage. So code like this:
ChildPackage::ChildSubPackage::ChildOfY.name.println() -- prints class name
works just fine. Also now I can create instances of ChildOfY in the DO
block of FIX statement of the constraint:
childOfY.println(); -- ok
But I can see changes to the diagram only after I refresh it with pressing
F5 which is not very convenient.
Also writing the same code in some operation throws an exception
"java.lang.IllegalStateException: Cannot modify resource set without a
write transaction". Though if I press F5 after that, the new node ChildOfY
will be shown in the diagram.
> Hi Yuri,
> of addNamespaceUri.
> Cheers,
> Dimitris
> Yuri G wrote:
>> Hello, Dimitris!
>>> Cheers,
>>> Dimitris
>>> Yuri G wrote:
>>>> Sure, done:
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi Yuri,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> <CoreMM.ecore>
>>>>>>> <ChildMM.ecore>
>>>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #17852 is a reply to message #17842] |
Fri, 01 May 2009 08:51   |
Hi Yuri,
Looking into the F5 and exception issues now..
Dimitris
> pressing F5 which is not very convenient.
> ChildOfY will be shown in the diagram.
>> Hi Yuri,
>> instead of addNamespaceUri.
>> Cheers,
>> Dimitris
>> Yuri G wrote:
>>> Hello, Dimitris!
>>> 'Method 'addNamespaceUri' not found'.
>>> of the downloaded interim plug-ins and it found nothing.
>>>> a new ChildOfY you should now add the following line of code before:
>>>> Cheers,
>>>> Dimitris
>>>> Yuri G wrote:
>>>>> Sure, done:
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> Hi Yuri,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> <CoreMM.ecore>
>>>>>>>> <ChildMM.ecore>
>>>>>>>> namespaceURI:
>>>>>>>> to it into the validated ClassX if needed. But there's no way I
>>>>>>>> can get to ChildOfY EClass to create its instance.
>>>>>>>> I can't access this package, because it has another namespaceURI
| Re: Accessing subpackages in EVL [message #17867 is a reply to message #17852] |
Fri, 01 May 2009 09:20   |
Hi Yuri,
Unfortunately, I'm not able to reproduce this with the mindmap editor.
Could you please send me a copy of your plugins (or a minimal example
that reproduces the problem) so that I can test more?
Is this only happening only when you are trying to instantiate classes
from the added metamodel or for all classes?
Dimitris
> Hi Yuri,
> Cheers,
> Dimitris
>> from the added EPackage. So code like this:
>> name
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>> Yuri G wrote:
>>>> Hello, Dimitris!
>>>>> create a new ChildOfY you should now add the following line of code
>>>>> before:
>>>>> another go tomorrow with a clearer mind.
>>>>> Cheers,
>>>>> Dimitris
>>>>> Yuri G wrote:
>>>>>> Sure, done:
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> Hi Yuri,
>>>>>>>> now and will hopefully release a new interim version later on
>>>>>>>> today.
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> <CoreMM.ecore>
>>>>>>>>> <ChildMM.ecore>
>>>>>>>>> namespaceURI:
>>>>>>>>> apparently, I can't access this package, because it has another
>>>>>>>>> namespaceURI than CorePackage and resides in another .ecore file.
| Re: Accessing subpackages in EVL [message #17881 is a reply to message #17867] |
Fri, 01 May 2009 14:31   |
Hi Dimitris,
Well, I guess I found out that pressing F5 is needed because I didn't
actually add the created instance of ChildOfY to the validated ClassX. Now
it shows in the diagram immediately. So this issue is solved.
Also if I just create the variable of type ClassX and don't "insert" into
the diagram's domain element it would not be shown either (until I press
F5). Though if I save the diagram (even without refreshing it), this
instance of ClassX would be added to the model file, but as an "outside"
head XMI node like this:
<xmi:XMI ....>
<CoreClass/> // this is diagram node
<ClassX/> // this variable was defined in the quick-fix
</xmi:XMI>
I'm going to test addMetamodelUri on the weekend more and write you back
if the problem with exception persists or anything (I've just tried to
reproduce the exception, unsuccessfully...).
Thank for you very much for your replies and the patch, Dimitris!
Regards, Yuri.
> Hi Yuri,
> Cheers,
> Dimitris
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> name
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>> Yuri G wrote:
>>>>> Hello, Dimitris!
>>>>>> before:
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Yuri G wrote:
>>>>>>> Sure, done:
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> Hi Yuri,
>>>>>>>>> today.
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #17894 is a reply to message #17881] |
Sun, 03 May 2009 03:38   |
Hello, Dimitris,
I think I've found the sources of the reported errors. They're not caused
by using addMetamodelUri().
1. java.lang.IllegalState exception was caused by instantiating metamodel
element in the operation which is called from the 'check' block. Example
for the Mindmap example:
context Map {
constraint Test {
check : poo()
message : 'test!'
operation poo() : Boolean {
var t : new Topic; -- exception here
return false;
Shall I create a bug-report?
2. About the problem with need to refresh the diagram after quick-fix. It
seems that quick fixes work correctly in most cases (i.e. the user doesn't
have to refresh nor re-initialize the diagram file manually).
Though I've sent you a minimal project which reproduces such behavior. I
have the same case in my own project. There's a diagram link used to
represent a containment feature of class A. Class A contains instances of
class B. If in the EVL quick-fix I try to create an instance of B and add
it to the validated A, it wouldn't be shown on the diagram immediately.
Though the changes would be saved to the model file. Any suggestions?
Regards, Yuri
Yuri G wrote:
> Hi Dimitris,
> <xmi:XMI ....>
> </xmi:XMI>
> Regards, Yuri.
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>>> name
>>>>> Hi Yuri,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Yuri G wrote:
>>>>>> Hello, Dimitris!
>>>>>>> before:
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Yuri G wrote:
>>>>>>>> Sure, done:
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>>> Hi Yuri,
>>>>>>>>>> today.
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitris
>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #17908 is a reply to message #17894] |
Thu, 07 May 2009 12:06   |
Hi Yuri,
Apologies for the late response. It's been a very busy week. Please see
comments below:
Yuri G wrote:
> Hello, Dimitris,
> caused by using addMetamodelUri().
> metamodel element in the operation which is called from the 'check'
> block. Example for the Mindmap example:
> context Map {
> constraint Test {
> check : poo()
> message : 'test!'
> return false;
Is there any specific reason why you'd want to create objects in the
check part? By default the check part runs in read-only mode (hence the
exception) but again if you have a good reason I'm happy to change this...
> It seems that quick fixes work correctly in most cases (i.e. the user
> doesn't have to refresh nor re-initialize the diagram file manually).
> of class B. If in the EVL quick-fix I try to create an instance of B and
> add it to the validated A, it wouldn't be shown on the diagram
> immediately. Though the changes would be saved to the model file. Any
> suggestions?
I'll check with the example you've sent me and get back to you on this
shortly.
> Regards, Yuri
Dimitris
> Yuri G wrote:
>> Hi Dimitris,
>> Now it shows in the diagram immediately. So this issue is solved.
>> into the diagram's domain element it would not be shown either (until
>> I press F5). Though if I save the diagram (even without refreshing
>> it), this instance of ClassX would be added to the model file, but as
>> an "outside" head XMI node like this:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <xmi:XMI ....>
>> </xmi:XMI>
>> back if the problem with exception persists or anything (I've just
>> tried to reproduce the exception, unsuccessfully...).
>> Regards, Yuri.
>>> Hi Yuri,
>>> editor. Could you please send me a copy of your plugins (or a minimal
>>> example that reproduces the problem) so that I can test more?
>>> classes from the added metamodel or for all classes?
>>> Cheers,
>>> Dimitris
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> class name
>>>>> DO block of FIX statement of the constraint:
>>>>> without a write transaction". Though if I press F5 after that, the
>>>>> new node ChildOfY will be shown in the diagram.
>>>>>> Hi Yuri,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Yuri G wrote:
>>>>>>> Hello, Dimitris!
>>>>>>> codes of the downloaded interim plug-ins and it found nothing.
>>>>>>>> code before:
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>> Yuri G wrote:
>>>>>>>>> Sure, done:
>>>>>>>>>> request about this in the bugzilla so that we can keep track
>>>>>>>>>> of this?
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitris
>>>>>>>>>>> Hi Yuri,
>>>>>>>>>>> today.
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitris
>>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>>> for ClassX and ChildOfY meta-elements.
>>>>>>>>>>>> namespaceURI:
>>>>>>>>>>>> which would create a ChildOfY node in my diagram and add a
>>>>>>>>>>>> reference to it into the validated ClassX if needed. But
>>>>>>>>>>>> there's no way I can get to ChildOfY EClass to create its
>>>>>>>>>>>> instance.
>>>>>>>>>>>> another namespaceURI than CorePackage and resides in another
>>>>>>>>>>>> .ecore file.
>>>>>>>>>>>> this quick-fix. But I haven't looked into EWL much, so I'm
| Re: Accessing subpackages in EVL [message #17922 is a reply to message #17908] |
Thu, 07 May 2009 12:32  |
> Hi Yuri,
Sure, no problem.
I see. Initially I instantiated an object in check part by accident. I
don't really need such functionality in my project at the moment. Though I
don't see much reason against such functionality except accidental
modification of the validated node (to prevent errors similar to writing
if(a=b) instead of if(a==b) in C). This feature can be even used to
automatically perform quick-fixes from the check block without need for
user to go to the context menu (for example if the mistake is
simple/obvious and doesn't need user's prompt). Or there can be some
Checker object instantiated for the validation of the selected node. Or it
could be a MetricCalculator class created during validation of a Class
node in UML diagram. Just some ideas off the top of my head.
> shortly.
Thank you very much, looking forward to this.
>> Yuri G wrote:
>>> Hi Dimitris,
>>> <xmi:XMI ....>
>>> </xmi:XMI>
>>> Regards, Yuri.
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Yuri,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> class name
>>>>>>> Hi Yuri,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Yuri G wrote:
>>>>>>>> Hello, Dimitris!
>>>>>>>>> code before:
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>> Yuri G wrote:
>>>>>>>>>> Sure, done:
>>>>>>>>>>> of this?
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitris
>>>>>>>>>>>> Hi Yuri,
>>>>>>>>>>>> today.
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Dimitris
>>>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>>>> namespaceURI:
>>>>>>>>>>>>> instance.
>>>>>>>>>>>>> .ecore file.
| Re: Accessing subpackages in EVL [message #567416 is a reply to message #16904] |
Thu, 30 April 2009 08:05  |
Hi Yuri,
If you only have one model, you can skip the ModelName! part and just
use packagename::classname
Dimitris
Yuri G wrote:
> Hello!
> subpackage's classes?
> access to metamodel's elements like:
| Re: Accessing subpackages in EVL [message #567428 is a reply to message #16965] |
Thu, 30 April 2009 08:40  |
> Hi Yuri,
this should read PackageA::subPackageOfPackageA::subClass
> Cheers,
> Dimitris
> Yuri G wrote:
>> Hello!
>> .evl file which is associated with PackageA.
| Re: Accessing subpackages in EVL [message #567447 is a reply to message #16992] |
Thu, 30 April 2009 09:05  |
It works this way. Thank you very much, Dimitris!
Yet another question: is it possible to access arbitrary metamodel from my
evl constraint?
For example in QVTO there's a 'modeltype' construction which gives access
to any metamodel:
modeltype MINDMAP uses mindmap('http://www.example.org/mindmap');
var myTopic := object MINDMAP::Topic {};
| Re: Accessing subpackages in EVL [message #567473 is a reply to message #17021] |
Thu, 30 April 2009 09:39  |
Hi Yuri,
In the current version you only have access to the metamodel specified
in the namespaceURI attribute of the extension. Can I ask what's your
use case for this? We'd certainly be happy to support this in future
versions of Epsilon if there's good motivation.
Dimitris
> my evl constraint?
> access to any metamodel:
| Re: Accessing subpackages in EVL [message #567496 is a reply to message #17050] |
Thu, 30 April 2009 10:47  |
<CoreMM.ecore>
<ChildMM.ecore>
tried to access it from my .evl file. But, apparently, I can't access this
package, because it has another namespaceURI than CorePackage and resides
| Re: Accessing subpackages in EVL [message #567571 is a reply to message #17079] |
Hi Yuri,
Dimitris
> <CoreMM.ecore>
> <ChildMM.ecore>
| Re: Accessing subpackages in EVL [message #567593 is a reply to message #17165] |
Dimitris
> Hi Yuri,
> Cheers,
> Dimitris
>> <CoreMM.ecore>
>> <ChildMM.ecore>
>> even possible.
| Re: Accessing subpackages in EVL [message #567636 is a reply to message #17194] |
Sure, done:
> Cheers,
> Dimitris
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> <CoreMM.ecore>
>>> <ChildMM.ecore>
>>> even possible.
| Re: Accessing subpackages in EVL [message #567649 is a reply to message #17249] |
http://download.eclipse.org/modeling/gmt/epsilon/interim/ To create a
Dimitris
Yuri G wrote:
> Sure, done:
>> Cheers,
>> Dimitris
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>>> <CoreMM.ecore>
>>>> <ChildMM.ecore>
>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #567708 is a reply to message #17276] |
Hello, Dimitris!
> Cheers,
> Dimitris
> Yuri G wrote:
>> Sure, done:
>>> Cheers,
>>> Dimitris
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> <CoreMM.ecore>
>>>>> <ChildMM.ecore>
>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #567738 is a reply to message #17353] |
Hi Yuri,
of addNamespaceUri.
Dimitris
Yuri G wrote:
> Hello, Dimitris!
>> Cheers,
>> Dimitris
>> Yuri G wrote:
>>> Sure, done:
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Yuri,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> <CoreMM.ecore>
>>>>>> <ChildMM.ecore>
>>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #567766 is a reply to message #17374] |
> Hi Yuri,
> of addNamespaceUri.
> Cheers,
> Dimitris
> Yuri G wrote:
>> Hello, Dimitris!
>>> Cheers,
>>> Dimitris
>>> Yuri G wrote:
>>>> Sure, done:
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi Yuri,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> <CoreMM.ecore>
>>>>>>> <ChildMM.ecore>
>>>>>>> it's even possible.
| Re: Accessing subpackages in EVL [message #567798 is a reply to message #17842] |
Hi Yuri,
Dimitris
>> Hi Yuri,
>> Cheers,
>> Dimitris
>> Yuri G wrote:
>>> Hello, Dimitris!
>>>> Cheers,
>>>> Dimitris
>>>> Yuri G wrote:
>>>>> Sure, done:
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> Hi Yuri,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> <CoreMM.ecore>
>>>>>>>> <ChildMM.ecore>
>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #567829 is a reply to message #17852] |
Hi Yuri,
Dimitris
> Hi Yuri,
> Cheers,
> Dimitris
>> name
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>> Yuri G wrote:
>>>> Hello, Dimitris!
>>>>> before:
>>>>> Cheers,
>>>>> Dimitris
>>>>> Yuri G wrote:
>>>>>> Sure, done:
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> Hi Yuri,
>>>>>>>> today.
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> <CoreMM.ecore>
>>>>>>>>> <ChildMM.ecore>
>>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #567855 is a reply to message #17867] |
Hi Dimitris,
<xmi:XMI ....>
</xmi:XMI>
Regards, Yuri.
> Hi Yuri,
> Cheers,
> Dimitris
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> name
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>> Yuri G wrote:
>>>>> Hello, Dimitris!
>>>>>> before:
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Yuri G wrote:
>>>>>>> Sure, done:
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> Hi Yuri,
>>>>>>>>> today.
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #567883 is a reply to message #17881] |
Hello, Dimitris,
context Map {
constraint Test {
check : poo()
message : 'test!'
return false;
Regards, Yuri
Yuri G wrote:
> Hi Dimitris,
> <xmi:XMI ....>
> </xmi:XMI>
> Regards, Yuri.
>> Hi Yuri,
>> Cheers,
>> Dimitris
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>>> name
>>>>> Hi Yuri,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Yuri G wrote:
>>>>>> Hello, Dimitris!
>>>>>>> before:
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Yuri G wrote:
>>>>>>>> Sure, done:
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>>> Hi Yuri,
>>>>>>>>>> today.
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitris
>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>> namespaceURI:
| Re: Accessing subpackages in EVL [message #567912 is a reply to message #17894] |
Hi Yuri,
comments below:
Yuri G wrote:
> Hello, Dimitris,
> context Map {
> constraint Test {
> check : poo()
> message : 'test!'
> return false;
> suggestions?
shortly.
> Regards, Yuri
Dimitris
> Yuri G wrote:
>> Hi Dimitris,
>> <xmi:XMI ....>
>> </xmi:XMI>
>> Regards, Yuri.
>>> Hi Yuri,
>>> Cheers,
>>> Dimitris
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> class name
>>>>>> Hi Yuri,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Yuri G wrote:
>>>>>>> Hello, Dimitris!
>>>>>>>> code before:
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>> Yuri G wrote:
>>>>>>>>> Sure, done:
>>>>>>>>>> of this?
>>>>>>>>>> Cheers,
>>>>>>>>>> Dimitris
>>>>>>>>>>> Hi Yuri,
>>>>>>>>>>> today.
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitris
>>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>>> namespaceURI:
>>>>>>>>>>>> instance.
>>>>>>>>>>>> .ecore file.
| Re: Accessing subpackages in EVL [message #567941 is a reply to message #17908] |
> Hi Yuri,
Sure, no problem.
> shortly.
>> Yuri G wrote:
>>> Hi Dimitris,
>>> <xmi:XMI ....>
>>> </xmi:XMI>
>>> Regards, Yuri.
>>>> Hi Yuri,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Yuri,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> class name
>>>>>>> Hi Yuri,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Yuri G wrote:
>>>>>>>> Hello, Dimitris!
>>>>>>>>> code before:
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>> Yuri G wrote:
>>>>>>>>>> Sure, done:
>>>>>>>>>>> of this?
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Dimitris
>>>>>>>>>>>> Hi Yuri,
>>>>>>>>>>>> today.
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Dimitris
>>>>>>>>>>>>> <CoreMM.ecore>
>>>>>>>>>>>>> <ChildMM.ecore>
>>>>>>>>>>>>> namespaceURI:
>>>>>>>>>>>>> instance.
>>>>>>>>>>>>> .ecore file.
Current Time: Thu Oct 30 14:10:28 EDT 2025
Powered by FUDForum. Page generated in 0.38296 seconds
