| Intersects [message #179043] |
Mon, 25 April 2005 11:26  |
Originally posted by: james.willans.xactium.com
After almost two years of using GEF, I have to say that sometimes the
coordinate system still confuses me. In this instance I want to simply
test to see whether two figures intersect (one is some text on a
connection edge, the other is a node - although this detail is probably
not relevant).
So given those two figures:
IFigure text;
IFigure node;
My understanding is that text.getBounds().intersect(node.getBounds()) is
not guaranteed to work since each figure return the bounds according to
its coordinate system. However I thought that ensuring both bounds were
absolute:
Rectangle textRect = text.getBounds().getCopy();
text.translateToAbsolute(textRect);
Rectangle nodeRect = node.getBounds().getCopy();
node.translateToAbsolute(nodeRect);
would guarantee that both rectangles are in the same coordinate system,
and I could susbsequently test for:
textRect.getBounds().intersects(nodeRect);
However, this doesn't seem to work. Any ideas?
Thanks.
James
| Re: Intersects [message #179205 is a reply to message #179043] |
Mon, 25 April 2005 17:36  |
"James Willans" <james.willans@xactium.com> wrote in message
news:10ff81388d9b5a5c4c495f5326d84e10$1@www.eclipse.org...
> not relevant).
> IFigure text;
> IFigure node;
> absolute:
There is no getBounds() method on Rectangle, so you couldn't possibly be
doing exactly what you mention here. If you're invoking text.getBounds()
here, that obviously is your problem.
> Thanks.
> James
FUDForum. Page generated in 0.03796 seconds
