Home » Eclipse Projects » GEF » canExecute and feedback by MessageBox
canExecute and feedback by MessageBox [message #178674] Thu, 21 April 2005 04:44 Go to next message
Originally posted by: tkoray.aselsan.com.tr
I want to show an MessageBox to inform the user that a deletion of an
object cannot be done for some reason. So I override the canExecute
method of my deletecommand and add some code to open a messagebox. But
this time it shows the messagebox everytime I select the object.
So I moved the code to execute method so when I press "DEL", it displays
the messagebox but not really delete the object. But now this makes my
editor dirty.
Long story short, what is a good way to show a message box in such a
situation? Or is it better to show feedback differently?
Tankut Koray
Re: canExecute and feedback by MessageBox [message #178974 is a reply to message #178674] Sun, 24 April 2005 23:54 Go to previous messageGo to next message
Why is the delete action enabled if the user cannot delete the item? I
would say the action should display the message, but the action's run()
method shouldn't even be reachable if the item is not deletable.
"Tankut Koray" <tkoray@aselsan.com.tr> wrote in message
news:d47pbb$in9$1@news.eclipse.org...
> object cannot be done for some reason. So I override the canExecute method
> of my deletecommand and add some code to open a messagebox. But this time
> editor dirty.
> Tankut Koray
Re: canExecute and feedback by MessageBox [message #179514 is a reply to message #178974] Thu, 28 April 2005 01:05 Go to previous message
Ok than which method of delete command to place "display the message"
part? if I pu it in canExecute method, when I select the figure message
the message is displayed immidiately without pressing the "DEL" key.
>>Hi,
>>editor dirty.
>>Thanks,
>>Tankut Koray
Previous Topic:How to use ShortestPathConnectionRouter
Next Topic:refresh all editpart
Current Time: Thu Nov 20 01:53:54 EST 2025
Powered by FUDForum. Page generated in 0.04063 seconds
