Home » Language IDEs » Java Development Tools (JDT) » Cycle in build path
Cycle in build path [message #178601] Mon, 20 September 2004 23:26 Go to next message
Originally posted by: me.BarryBurd.com
Eclipse is complaining because I have a cycle in my build path. (See the
code below.) I understand that there's a cycle, but does this mean that
certain legal Java code is illegal in Eclipse? The code compiles and runs
with javac, but Eclipse finds the structure to be objectionable. Does this
mean that some valid code can't be imported into Eclipse?
Here's the (admittedly convoluted) code:
In project Drawings:......
package com.allmycode.drawings;
import java.awt.Graphics;
public class Drawing {
protected int x = 40, y = 40, width = 40, height = 40;
public void paint(Graphics g) {
g.drawOval(x, y, width, height);
import com.allmycode.frames.ArtFrame;
class ShowFrameWideBB {
public static void main(String args[]) {
Drawing drawing = new Drawing();
drawing.width = 100;
drawing.height = 30;
ArtFrame artFrame = new ArtFrame(drawing);
artFrame.setSize(200, 100);
artFrame.setVisible(true);
In project Frames:......
package com.allmycode.frames;
import com.allmycode.drawings.*;
import javax.swing.JFrame;
public class ArtFrame extends JFrame {
Drawing drawing;
public ArtFrame(Drawing drawing) {
this.drawing = drawing;
setTitle("Abstract Art");
setDefaultCloseOperation(EXIT_ON_CLOSE);
drawing.paint(g);
Re: Cycle in build path [message #178644 is a reply to message #178601] Tue, 21 September 2004 05:27 Go to previous messageGo to next message
Cycles in code are no problem. The problem are cyclic build paths - e.g.
ProjectA has ProjectB on its build path, and ProjectB has ProjectA on its
build path.
If you really need circular dependencies and don't care about possible
performance hits, you can switch the check off in Preferences > Java >
Compiler > Build Path: Set "Circular dependencies" to "Warning".
HTH
Markus
> Drawing drawing;
> drawing.paint(g);
Re: Cycle in build path [message #178692 is a reply to message #178644] Tue, 21 September 2004 10:30 Go to previous messageGo to next message
Thank you, Markus. I have a follow up question. On the Project Properties
sheet there's a page called Project References. I suspect that this is
related to the build path, but I can't figure out what effect checking
things Project References page has. Can you help? Thanks.
Re: Cycle in build path [message #178714 is a reply to message #178692] Tue, 21 September 2004 11:07 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Basically for java projects ignore the "Project References." This is for
controlling non-java builders. For java projects the projects required
to compile the project are controlled through the Java Build Path
instead from the Projects tab on the build path.
Thanks, Rich Kulp
Previous Topic:package/subdirectory question
Next Topic:unable to view debug vars in JDK class HashMap
Current Time: Thu Jul 24 21:12:11 EDT 2025
Powered by FUDForum. Page generated in 0.04627 seconds
