Home » Modeling » Epsilon » epsilon 0.8.5 generation problem
epsilon 0.8.5 generation problem [message #16868] Thu, 30 April 2009 07:57 Go to next message
after i updated to version 0.8.5 I keep getting the exception below every
time I use eugenia gmf generator. ecore file was not changed from 0.8.4
and did work perfect with old version. any idea how to make it work? I
lost my 0.8.4 installation, is there any way to download 0.8.4 version
from somewhere?
thanks,
Dmitriy
EXCEPTION:
Internal error: java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign[BasicEList.jav a:191]
at org.eclipse.emf.common.util.BasicEList.addUnique[BasicEList. java:645]
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique[NotifyingListImpl.java:331]
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue[NotifyingListImpl.java:288]
at org.eclipse.emf.common.util.BasicEList.add[BasicEList.java:6 26]
at org.eclipse.epsilon.eol.types.EolSet.addAll[EolSet.java:47]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
at java.lang.reflect.Method.invoke[Unknown Source]
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:123]
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:99]
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:179]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:66]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:36]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:122]
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[E xecutorFactory.java:184]
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te[StatementBlockExecutor.java:33]
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute [ForStatementExecutor.java:115]
at org.eclipse.epsilon.eol.EolModule.execute[EolModule.java:57]
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl[EolTransformationActionDelegate.java:102]
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run[EolTransformationActionDelegate.java:56]
at org.eclipse.core.internal.jobs.Worker.run[Worker.java:55]
(155:33)
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:191)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:645)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:288)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26)
at org.eclipse.epsilon.eol.types.EolSet.addAll(EolSet.java:47)
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:123)
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:99)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:179)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:66)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:36)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:122)
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:184)
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:115)
at org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl(EolTransformationActionDelegate.java:102)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run(EolTransformationActionDelegate.java:56)
Re: epsilon 0.8.5 generation problem [message #16935 is a reply to message #16868] Thu, 30 April 2009 08:04 Go to previous messageGo to next message
Hi Dmitriy,
This may be a regression. In which step does this happen? Could you
please send me the ecore so that I can investigate?
In the meantime you can downgrade to 0.8.4 from this update site:
http://download.eclipse.org/modeling/gmt/epsilon/updates.0.8 .4/
Dimitris
> every time I use eugenia gmf generator. ecore file was not changed from
> 0.8.4 and did work perfect with old version. any idea how to make it
> work? I lost my 0.8.4 installation, is there any way to download 0.8.4
> version from somewhere?
> thanks,
> Dmitriy
> EXCEPTION:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> (155:33)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: epsilon 0.8.5 generation problem [message #17108 is a reply to message #16935] Thu, 30 April 2009 11:47 Go to previous messageGo to next message
thanks Dimitris,
here is an example of my ecore file:
<BEGIN>
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmi:id="_B0BEoCV0Ed68UMxPtM2EBA" name="test" nsURI="test" nsPrefix="test">
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0BEoSV0Ed68UMxPtM2EBA"
name="IAAModel">
<eAnnotations xmi:id="_B0BEoiV0Ed68UMxPtM2EBA" source="gmf.diagram">
<details xmi:id="_B0BEoyV0Ed68UMxPtM2EBA" key="foo" value="bar"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference"
xmi:id="_B0BEpCV0Ed68UMxPtM2EBA" name="marketablePproduct" upperBound="-1"
eType="_B0BE0iV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BEpSV0Ed68UMxPtM2EBA" name="productComponent" upperBound="-1"
eType="_B0BE2iV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BErSV0Ed68UMxPtM2EBA"
name="marketableProductProductComponentCompositionRule" upperBound="-1"
eType="_B0BFGiV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BEtSV0Ed68UMxPtM2EBA"
name="productComponentProductComponentCompositionRule" upperBound="-1"
eType="_B0BFYiV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BEyCV0Ed68UMxPtM2EBA" name="marketableProductKinds"
eType="_B0KO9SV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BEySV0Ed68UMxPtM2EBA" name="productComponentKinds"
eType="_B0KO9yV0Ed68UMxPtM2EBA" containment="true"/>
xmi:id="_B0BE0SV0Ed68UMxPtM2EBA" name="cardinalities"
eType="_B0KPByV0Ed68UMxPtM2EBA" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0BE0iV0Ed68UMxPtM2EBA"
name="MarketableProduct" eSuperTypes="_B0KPHCV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_B0BE0yV0Ed68UMxPtM2EBA" source="gmf.node">
<details xmi:id="_B0BE1CV0Ed68UMxPtM2EBA" key="figure"
value="iaa.figures.MarketableProductShape"/>
<details xmi:id="_B0BE1SV0Ed68UMxPtM2EBA" key="label.icon"
value="false"/>
<details xmi:id="_B0BE1iV0Ed68UMxPtM2EBA" key="label"
value="kindName"/>
<details xmi:id="_B0BE1yV0Ed68UMxPtM2EBA" key="label.format"
value="underline"/>
<details xmi:id="_B0BE2CV0Ed68UMxPtM2EBA" key="color"
value="142,229,238"/>
</eAnnotations>
xmi:id="_B0BE2SV0Ed68UMxPtM2EBA" name="kind"
eType="_B0KPCSV0Ed68UMxPtM2EBA"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0BE2iV0Ed68UMxPtM2EBA"
name="ProductComponent" eSuperTypes="_B0KPHCV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_B0BE2yV0Ed68UMxPtM2EBA" source="gmf.node">
<details xmi:id="_B0BE3CV0Ed68UMxPtM2EBA" key="figure"
value="iaa.figures.ProductComponentShape"/>
<details xmi:id="_B0BE3SV0Ed68UMxPtM2EBA" key="label.icon"
value="false"/>
<details xmi:id="_B0BE3iV0Ed68UMxPtM2EBA" key="label"
value="kindName"/>
<details xmi:id="_B0BE3yV0Ed68UMxPtM2EBA" key="label.format"
value="underline"/>
<details xmi:id="_B0BE4CV0Ed68UMxPtM2EBA" key="color"
value="250,128,114"/>
</eAnnotations>
xmi:id="_B0BE4SV0Ed68UMxPtM2EBA" name="kind"
eType="_B0KPCiV0Ed68UMxPtM2EBA"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0BFGiV0Ed68UMxPtM2EBA"
name="MarketableProductProductComponentCompositionRule"
eSuperTypes="_B0KO8SV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_B0BFGyV0Ed68UMxPtM2EBA" source="gmf.link">
<details xmi:id="_B0BFHCV0Ed68UMxPtM2EBA" key="source"
value="source"/>
<details xmi:id="_B0BFHSV0Ed68UMxPtM2EBA" key="target"
value="target"/>
</eAnnotations>
xmi:id="_B0BFHiV0Ed68UMxPtM2EBA" name="source"
eType="_B0BE0iV0Ed68UMxPtM2EBA"/>
xmi:id="_B0BFICV0Ed68UMxPtM2EBA" name="target"
eType="_B0BE2iV0Ed68UMxPtM2EBA"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0BFYiV0Ed68UMxPtM2EBA"
name="ProductComponentProductComponentCompositionRule"
<eAnnotations xmi:id="_B0BFYyV0Ed68UMxPtM2EBA" source="gmf.link">
<details xmi:id="_B0BFZCV0Ed68UMxPtM2EBA" key="source"
value="source"/>
<details xmi:id="_B0BFZSV0Ed68UMxPtM2EBA" key="target"
value="target"/>
</eAnnotations>
xmi:id="_B0BFZiV0Ed68UMxPtM2EBA" name="source"
xmi:id="_B0BFaCV0Ed68UMxPtM2EBA" name="target"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KO8CV0Ed68UMxPtM2EBA"
name="CompositionRuleWithoutCardinality"
eSuperTypes="_54tJ5DWYEd6_lp5Wz1QxFw"/>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KO8SV0Ed68UMxPtM2EBA"
name="CompositionRuleWithCardinality"
eSuperTypes="_54tJ5DWYEd6_lp5Wz1QxFw">
<eAnnotations xmi:id="_B0KO8iV0Ed68UMxPtM2EBA" source="gmf.link">
<details xmi:id="_B0KO8yV0Ed68UMxPtM2EBA" key="label"
value="cardinality.name"/>
</eAnnotations>
xmi:id="_B0KO9CV0Ed68UMxPtM2EBA" name="cardinality"
eType="_B0KPFSV0Ed68UMxPtM2EBA"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_54tJ5DWYEd6_lp5Wz1QxFw"
name="CompositionRule"/>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KO9SV0Ed68UMxPtM2EBA"
name="MarketableProductKinds">
xmi:id="_B0KO9iV0Ed68UMxPtM2EBA" name="marketableProductKind"
upperBound="-1" eType="_B0KPCSV0Ed68UMxPtM2EBA" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KO9yV0Ed68UMxPtM2EBA"
name="ProductComponentKinds">
xmi:id="_B0KO-CV0Ed68UMxPtM2EBA" name="productComponentKind"
upperBound="-1" eType="_B0KPCiV0Ed68UMxPtM2EBA" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPByV0Ed68UMxPtM2EBA"
name="Cardinalities">
xmi:id="_B0KPCCV0Ed68UMxPtM2EBA" name="cardinality" upperBound="-1"
eType="_B0KPFSV0Ed68UMxPtM2EBA" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPCSV0Ed68UMxPtM2EBA"
name="MarketableProductKind" eSuperTypes="_B0KPEiV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_54tJ5TWYEd6_lp5Wz1QxFw" source="pdfs.mapping">
<details xmi:id="_54tJ5jWYEd6_lp5Wz1QxFw" key="datatypeName"
value="MarketableProductKind"/>
<details xmi:id="_54tJ5zWYEd6_lp5Wz1QxFw" key="keytypeName"
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPCiV0Ed68UMxPtM2EBA"
name="ProductComponentKind" eSuperTypes="_B0KPEiV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_54tJ6DWYEd6_lp5Wz1QxFw" source="pdfs.mapping">
<details xmi:id="_54tJ6TWYEd6_lp5Wz1QxFw" key="datatypeName"
value="ProductComponentKind"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPEiV0Ed68UMxPtM2EBA"
name="Kind" eSuperTypes="_B0KPHCV0Ed68UMxPtM2EBA">
<eAnnotations xmi:id="_54tJ6jWYEd6_lp5Wz1QxFw" source="pdfs.mapping">
<details xmi:id="_54tJ6zWYEd6_lp5Wz1QxFw" key="keytype"
value="KeyType"/>
<details xmi:id="_54tJ7DWYEd6_lp5Wz1QxFw" key="keyvalue"
value="KeyValue"/>
<details xmi:id="_54tJ7TWYEd6_lp5Wz1QxFw" key="assoName"
value="KeyType - KeyValue"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPFSV0Ed68UMxPtM2EBA"
name="Cardinality">
<eStructuralFeatures xsi:type="ecore:EAttribute"
xmi:id="_B0KPFiV0Ed68UMxPtM2EBA" name="name">
<eType xsi:type="ecore:EDataType"
href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
xmi:id="_B0KPGCV0Ed68UMxPtM2EBA" name="minimum" defaultValueLiteral="0">
href="http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
xmi:id="_B0KPGiV0Ed68UMxPtM2EBA" name="maximum" defaultValueLiteral="1">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" xmi:id="_B0KPHCV0Ed68UMxPtM2EBA"
name="ProductEntity">
xmi:id="_B0KPHSV0Ed68UMxPtM2EBA" name="kindName" volatile="true">
xmi:id="_B0KPHyV0Ed68UMxPtM2EBA" name="name">
<eAnnotations xmi:id="_B0KPISV0Ed68UMxPtM2EBA" source="gmf.label">
<details xmi:id="_B0KPIiV0Ed68UMxPtM2EBA" key="foo" value="bar"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
<END>
Re: epsilon 0.8.5 generation problem [message #17139 is a reply to message #17108] Thu, 30 April 2009 11:48 Go to previous messageGo to next message
Many thanks Dmitriy. I'll investigate and get back to you.
Dimitris
Dmitriy N. wrote:
> thanks Dimitris,
> <BEGIN>
> name="IAAModel">
> </eAnnotations>
> upperBound="-1" eType="_B0BE0iV0Ed68UMxPtM2EBA" containment="true"/>
> </eClassifiers>
> value="false"/>
> value="kindName"/>
> value="underline"/>
> </eAnnotations>
> </eClassifiers>
> value="false"/>
> value="kindName"/>
> value="underline"/>
> </eAnnotations>
> </eClassifiers>
> value="source"/>
> value="target"/>
> </eAnnotations>
> </eClassifiers>
> value="source"/>
> value="target"/>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> value="KeyType"/>
> value="KeyValue"/>
> </eAnnotations>
> </eClassifiers>
> name="Cardinality">
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> <END>
Re: epsilon 0.8.5 generation problem [message #17303 is a reply to message #17139] Thu, 30 April 2009 15:05 Go to previous messageGo to next message
Hi Dmitriy,
Trying to generate the gmftool/graph/map, models from the model you sent
me does indeed raise an error but it doesn't appear to match with the
one in your previous message. The error I'm getting is:
Called feature eOpposite on undefined object (323:53)
and the reason is this class:
@gmf.link(label="cardinality.name")
class CompositionRuleWithCardinality extends CompositionRule {
ref Cardinality cardinality;
more specifically @gmf.link misses the source and target details which
are required. When I take out this annotation everything works as
expected. Perhaps another example could illustrate the problem a bit better.
Dimitris
> Cheers,
> Dimitris
> Dmitriy N. wrote:
>> thanks Dimitris,
>> <BEGIN>
>> <?xml version="1.0" encoding="UTF-8"?>
>> nsPrefix="test">
>> xmi:id="_B0BEoSV0Ed68UMxPtM2EBA" name="IAAModel">
>> </eAnnotations>
>> upperBound="-1" eType="_B0BE2iV0Ed68UMxPtM2EBA" containment="true"/>
>> upperBound="-1" eType="_B0BFGiV0Ed68UMxPtM2EBA" containment="true"/>
>> </eClassifiers>
>> xmi:id="_B0BE0iV0Ed68UMxPtM2EBA" name="MarketableProduct"
>> value="false"/>
>> value="kindName"/>
>> value="underline"/>
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_B0BE2iV0Ed68UMxPtM2EBA" name="ProductComponent"
>> value="false"/>
>> value="kindName"/>
>> value="underline"/>
>> </eAnnotations>
>> </eClassifiers>
>> value="source"/>
>> value="target"/>
>> </eAnnotations>
>> </eClassifiers>
>> value="source"/>
>> value="target"/>
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_B0KO8SV0Ed68UMxPtM2EBA" name="CompositionRuleWithCardinality"
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_54tJ5DWYEd6_lp5Wz1QxFw" name="CompositionRule"/>
>> xmi:id="_B0KO9SV0Ed68UMxPtM2EBA" name="MarketableProductKinds">
>> </eClassifiers>
>> xmi:id="_B0KO9yV0Ed68UMxPtM2EBA" name="ProductComponentKinds">
>> </eClassifiers>
>> xmi:id="_B0KPByV0Ed68UMxPtM2EBA" name="Cardinalities">
>> </eClassifiers>
>> xmi:id="_B0KPCSV0Ed68UMxPtM2EBA" name="MarketableProductKind"
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_B0KPCiV0Ed68UMxPtM2EBA" name="ProductComponentKind"
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_B0KPEiV0Ed68UMxPtM2EBA" name="Kind"
>> value="KeyType"/>
>> value="KeyValue"/>
>> </eAnnotations>
>> </eClassifiers>
>> xmi:id="_B0KPFSV0Ed68UMxPtM2EBA" name="Cardinality">
>> </eClassifiers>
>> xmi:id="_B0KPHCV0Ed68UMxPtM2EBA" name="ProductEntity">
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> <END>
Re: epsilon 0.8.5 generation problem [message #17329 is a reply to message #17303] Thu, 30 April 2009 16:11 Go to previous message
Dimitris,
this is exactly the error i got, but i sent you the whole exception stack.
it looks like in 0.8.4 these annotation details was not required.
I will modify my ecore file to make it work,
thanks for your help,
Dmitriy
Re: epsilon 0.8.5 generation problem [message #567396 is a reply to message #16868] Thu, 30 April 2009 08:04 Go to previous message
Hi Dmitriy,
Dimitris
> thanks,
> Dmitriy
> EXCEPTION:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> (155:33)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: epsilon 0.8.5 generation problem [message #567524 is a reply to message #16935] Thu, 30 April 2009 11:47 Go to previous message
thanks Dimitris,
<BEGIN>
name="IAAModel">
</eAnnotations>
</eClassifiers>
value="false"/>
value="kindName"/>
value="underline"/>
</eAnnotations>
</eClassifiers>
value="false"/>
value="kindName"/>
value="underline"/>
</eAnnotations>
</eClassifiers>
value="source"/>
value="target"/>
</eAnnotations>
</eClassifiers>
value="source"/>
value="target"/>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
value="KeyType"/>
value="KeyValue"/>
</eAnnotations>
</eClassifiers>
name="Cardinality">
</eClassifiers>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
<END>
Re: epsilon 0.8.5 generation problem [message #567549 is a reply to message #17108] Thu, 30 April 2009 11:48 Go to previous message
Dimitris
Dmitriy N. wrote:
> thanks Dimitris,
> <BEGIN>
> name="IAAModel">
> </eAnnotations>
> </eClassifiers>
> value="false"/>
> value="kindName"/>
> value="underline"/>
> </eAnnotations>
> </eClassifiers>
> value="false"/>
> value="kindName"/>
> value="underline"/>
> </eAnnotations>
> </eClassifiers>
> value="source"/>
> value="target"/>
> </eAnnotations>
> </eClassifiers>
> value="source"/>
> value="target"/>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> value="KeyType"/>
> value="KeyValue"/>
> </eAnnotations>
> </eClassifiers>
> name="Cardinality">
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> <END>
Re: epsilon 0.8.5 generation problem [message #567670 is a reply to message #17139] Thu, 30 April 2009 15:05 Go to previous message
Hi Dmitriy,
Dimitris
> Cheers,
> Dimitris
> Dmitriy N. wrote:
>> thanks Dimitris,
>> <BEGIN>
>> nsPrefix="test">
>> </eAnnotations>
>> </eClassifiers>
>> value="false"/>
>> value="kindName"/>
>> value="underline"/>
>> </eAnnotations>
>> </eClassifiers>
>> value="false"/>
>> value="kindName"/>
>> value="underline"/>
>> </eAnnotations>
>> </eClassifiers>
>> value="source"/>
>> value="target"/>
>> </eAnnotations>
>> </eClassifiers>
>> value="source"/>
>> value="target"/>
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> value="KeyType"/>
>> value="KeyValue"/>
>> </eAnnotations>
>> </eClassifiers>
>> </eClassifiers>
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> <END>
Re: epsilon 0.8.5 generation problem [message #567690 is a reply to message #17303] Thu, 30 April 2009 16:11 Go to previous message
Dimitris,
Dmitriy
Previous Topic:Accessing subpackages in EVL
Next Topic:Accessing subpackages in EVL
Current Time: Wed Nov 19 13:57:48 EST 2025
Powered by FUDForum. Page generated in 0.27546 seconds
