| How to invoke all project builders? [message #178510] |
Tue, 05 September 2006 02:14  |
Originally posted by: borut.bolcina.gmail.com
I am developing a web project (with Tapestry) with WTP 1.5 (Tomcat 5.5).
All is OK, except that this web application is also a RMI client, so
stubs have to be made. RMI compiler (eclipse genady plugin) is invoked
when cleaning the project or on demand, but when I change something in
my running (hot deploy) application, the application gets recompiled on
the fly, but the RMI compiler is not invoked. Is there a way to persuade
WTP to invoke the RMI Builder which is listed and checked in project's
Preferences/Builders?
Borut
| Re: How to invoke all project builders? [message #178829 is a reply to message #178695] |
Sat, 09 September 2006 14:52   |
When I change Java source and save, this happens
9.9.2006 20:38:40 org.apache.catalina.core.StandardContext reload
INFO: Reloading this Context has started
9.9.2006 20:38:41 org.apache.catalina.loader.WebappClassLoader
validateJarFile
INFO: validateJarFile(C:\Documents and
Settings\borutb\Desktop\Workspace\.metadata\.plugins\org.ecl ipse.wst.se
rver.core\tmp0\webapps\post\WEB-INF\lib\servlet-api-2.4.jar) - jar not
loaded. See Servlet Spec 2.3, section 9
..7.2. Offending class: javax/servlet/Servlet.class
INFO [09 sep 2006 20:38:43:765] Initialized application servlet
'posting': 984 millis to create HiveMind Regi
stry, 2.140 millis overall.
and stub class disappears from WEB-INF/classes. I have also Maven2
builder for my project, but of course it doesn't trigger, 'couse it is
only activated with external tools launcher. RMI builder
(http://www.genady.net/rmi/index.html) gets triggered when I do
Project/Clean or right click on project then RMI/Re-generate RMI Stubs.
Even this does not work if Tomcat is running as it immediately deletes
the stub class, so I have to shutdown Tomcat, regenerate stub, start
Tomcat and see changes. Horrible.
I guess I should contact the author of RMI plugin.
Borut
On 7.9.2006 20:08, Konstantin Komissarchik wrote:
> Borut,
> It sounds like the problem is with the RMI builder that you are using.
> Every builder gets a chance to execute its compilation logic whenever
> any resource in a project changes. The builder decides whether to take
> any action or not.
> - Konstantin
| Re: How to invoke all project builders? [message #179268 is a reply to message #178829] |
Mon, 18 September 2006 08:15  |
Can you confirm that the stubs disappear even when Tomcat is not
running, i.e. it is the Web Tools publish operation that is making them
disappear?
Larry
> validateJarFile
> Borut
>> Borut,
>> any action or not.
>> - Konstantin
FUDForum. Page generated in 0.04047 seconds
