Home » Language IDEs » ServerTools (WTP) » feature "Apache Xerces" / "Apache Jakarta log4j" disabled ?
feature "Apache Xerces" / "Apache Jakarta log4j" disabled ? [message #178459] Sat, 02 September 2006 11:29 Go to next message
Included feature "Apache Xerces" version
"2.8.0.v200605151647--08422828353873" is disabled.
Included feature "Apache Jakarta log4j" version
"1.2.8.v200605300321--0842282939426_" is disabled.
What is the cause of those "disabled" features and does any part of WTP
rely on being active?
This is after installing this weeks declared build. The previous 2 or 3
weeks of WTP1.5.1 builds only had Xerces disabled.
Darryl
Re: feature "Apache Xerces" / "Apache Jakarta log4j" disabled ? [message #178821 is a reply to message #178459] Sat, 09 September 2006 13:17 Go to previous messageGo to next message
On Sat, 02 Sep 2006 11:29:06 -0400, Darryl L. Miles <darryl@netbauds.net>
> Darryl
xerces is required for advanced xml validation (which might included xsd
validation, wsdl validation, etc., I'm not sure).
the log4j is required indirectly for some web services functions.
is this from you installing completeing fresh installs? from Zips? If so,
would be worth a bug report.
Re: feature "Apache Xerces" / "Apache Jakarta log4j" disabled ? [message #179386 is a reply to message #178821] Tue, 19 September 2006 07:25 Go to previous messageGo to next message
>> WTP rely on being active?
>> 3 weeks of WTP1.5.1 builds only had Xerces disabled.
> so, would be worth a bug report.
Same with this weeks I-Build, yes I am installing to empty eclipse
directory with ZIPs. But I do have some plugins in my home directory
that are picked up (these plugins are not upgraded week to week).
The best view is this problem is from Help -> Software Updates -> Manage
Installations; There are red cross decorators over the WTP feature.
Maybe I should attempt a clean install with only WTP and its pre-requisites.
Darryl
Re: feature "Apache Xerces" / "Apache Jakarta log4j" disabled ? [message #179465 is a reply to message #178459] Wed, 20 September 2006 14:26 Go to previous message
Okay today I nailed down the cause of this. Certain combinations of
Eclipse plugins cause this problem.
When BIRT and WTP are installed. I used:
birt-report-framework-sdk-2_1_0.zip
My configuration then had:
$ ls -1d eclipse/features/org.apache.xerces*
eclipse/features/org.apache.xerces_2.8.0.N20060628-1351 (from BIRT)
eclipse/features/org.apache.xerces.feature_2.8.0.v2006051516 47--08422828353873
(from WTP)
When TPTP and WTP are installed. I used:
tptp.runtime-TPTP-4.3.0-200609150100.zip
My configuration then has:
$ ls -1d eclipse/features/*log4j*
eclipse/features/org.apache.jakarta_log4j.feature_1.2.8.v200 605300321--08422828353873
(from TPTP)
eclipse/features/org.apache.jakarta_log4j.feature_1.2.8.v200 605300321--0842282939426_
(from WTP)
The red error indicators in Help -> Software Updates -> Manage
Configuration, seem a bit alarmist.
Maybe a problem for the Orbit project?
http://wiki.eclipse.org/index.php/Orbit
Still want a bug report ? Should I file against Orbit project to
arbitrate this problem in the future ?
Darryl
Previous Topic:problem loading localhost:8080 in eclipse
Next Topic:is there a way to programmatically add servers and server runtimes?
Current Time: Tue Nov 25 20:52:45 EST 2025
Powered by FUDForum. Page generated in 0.25808 seconds
