Home » Newcomers » Newcomers » Team -> Commit wants to commit files that I haven't added.
Team -> Commit wants to commit files that I haven't added. [message #178235] Fri, 03 November 2006 10:40 Go to next message
Originally posted by: cjbottaro.alumni.cs.utexas.edu
This is a major annoyance given the way my project is setup. For whatever
reason, a bunch of files get copied around in my project tree. Eclipse
sees these as new files (obviously), but the problem is when I do a Team ->
Commit at the project root, Eclipse wants to add/commit all those "new"
files.
How can I setup Eclipse to only commit new files that I have manually added
to CVS myself?
Thanks for the help,
-- Christopher
Re: Team -> Commit wants to commit files that I haven't added. [message #178364 is a reply to message #178235] Sat, 04 November 2006 01:18 Go to previous messageGo to next message
What new files are you talkoing about (filenames)?
Either Team/Add to .cvsignore or set /Properties/derived
Maarten
Christopher J. Bottaro schreef:
> Hello,
> files.
> to CVS myself?
> -- Christopher
Re: Team -> Commit wants to commit files that I haven't added. [message #178576 is a reply to message #178235] Mon, 06 November 2006 10:30 Go to previous message
Originally posted by: eclipse4.rizzoweb.com
Christopher J. Bottaro wrote:
> Hello,
> files.
> to CVS myself?
The problem is that Eclipse can't read your mind and doesn't know the
difference between files that were generated and ones that you "meant"
to create.
As someone already pointed out, .cvsignore is often used to keep
specific files and directories from CVS's attention.
I will also recommend that you use the Synchronize feature instead of
just Commit - the Synchronize view will allow you to preview all
potential changes and pick-and-choose which ones you want to actually
commit.
Hope this helps,
Eric
Previous Topic:Shutting down remote eclipse opens all desktop windows
Next Topic:BIRT to remote maven repository
Current Time: Sat Nov 01 19:47:57 EDT 2025
Powered by FUDForum. Page generated in 0.06991 seconds
