| Re: 1.5.1 and eclipse 3.3 M1 [message #177724 is a reply to message #177702] |
Tue, 22 August 2006 15:02   |
This is kinda weird. I can probably understand your concern from the
QA and support point of view. But from usability point of view, why
don't allow users to deal with this?
So, if somebody would want to run on unsupported configuration he on
his own and this is ok. You'll get early notifications/bug reports about
incompatibilities and can deal with them.
That would save some work to WTP and eliminate need in some
intermediate releases when platform API in fact haven't changed...
regards,
Eugene
Ed Merks wrote:
> Joerg,
> See
> http://dev.eclipse.org/mhonarc/lists/cross-project-issues-de v/msg00578.html
> Joerg von Frantzius wrote:
>> Out of curiosity, does anybody per chance know why WTP is explicitly
>> restricted to Eclipse versions 3.2 up to but not including 3.3.0?
>> (see also my comments on the bug). That's not the update site, but
>> WTP itself, I think.
>> Regards,
>> Jörg
>> Eugene Kuleshov schrieb:
>>> It looks like update site does not allow to install WTP on Eclipse
>>> 3.3M1 complaining about some platform dependencies. However after I
>>> installed WTP manually it does not work either.
>>> I suspect that one of WTP plugins has strict version restriction on
>>> one of the platform plugins (perhaps missing "+" or has version
>>> range up to 3.2 or something).
>>> This is quite sad because 3.3M1 haven't introduced any API
>>> incompatibilities yet...
>>> I opened issue for this
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=153752
>>> regards,
>>> Eugene
>>> Zohar wrote:
>>>> Can WTP 1.5.1 (wtp-M-1.5.1-200608110237.zip) work with eclipse 3.3 M1?
| Re: 1.5.1 and eclipse 3.3 M1 [message #177732 is a reply to message #177724] |
Tue, 22 August 2006 15:19   |
Eugene,
It's not actually my opinion. My personal opinion is earlier in that
thread (where I questioned the value of putting an arbitrary upper limit
ahead of knowing what the limit should really be). I.e., I mostly agree
with you. However, Tim does raise a good point that I hadn't
considered, i.e., internal implementations are much more likely to change...
> about incompatibilities and can deal with them.
> regards,
> Eugene
> Ed Merks wrote:
>> Joerg,
>> See
>>> Regards,
>>> Jörg
>>>> on one of the platform plugins (perhaps missing "+" or has version
>>>> regards,
>>>> Eugene
>>>>> M1?
| Re: 1.5.1 and eclipse 3.3 M1 [message #177739 is a reply to message #177732] |
Tue, 22 August 2006 15:49   |
Tim would definitely know better what part of the internal platform
API WTP depends on. What I don't understand is his the assumption that
internal API will definetely change.
Unfortunately, WTP has several places where we rely on internal (not
API) methods from the base…so in general, “loose” numbers really are
wrong, because the base can and does change those methods and “breaks”
WTP. Ultimately of course the answer is to eliminate non-API use and
then the upper bound could in principle be left unset, but it’s hard to
see a path to that point for a project as broad as WTP, where there’s
always some area that is always at the very edge of platform services.
I still think that users should have option to deal with this on
their own.
For example, somebody can create a fragment plugin that would "patch"
wtp stuff for changed internal API. That patch would of course have
stronger requirements for dependencies, but it only has to include wtp
classes that are affected by such change, so users won't have to
reinstall the whole wtp.
Note that this patch feature is in fact supported by platform update
manager and allows to distribute these patches from regular update sites.
regards,
Eugene
Ed Merks wrote:
> Eugene,
> change...
>> regards,
>> Eugene
>> Ed Merks wrote:
>>> Joerg,
>>> See
| Re: 1.5.1 and eclipse 3.3 M1 [message #177783 is a reply to message #177754] |
Wed, 23 August 2006 10:30  |
Originally posted by: joerg.von.frantzius.artnology.nospam.com
--------------040502020807000205060003
Hi Ed,
as I don't know of any other enhancement request in the bugzilla
proposing this flying without safety harness, I'd suggest anyone
interested to cast their votes on the bug
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=78381>. If it had e.g.
the votes of /the /Eds, maybe something is going to happen here ;-)
I guess it's a question of the OSGI implementation, so I wonder whether
Platform/Update is the right place for the enhancement request?
J
FUDForum. Page generated in 0.04960 seconds
