| Is there a way to import tasks? [message #16707] |
Wed, 07 May 2003 14:43  |
Originally posted by: pchen3.jhmi.edu
Hey All,
Is there a way I can import the tasks associated to a particular .java
file when I import the file into
another project? Thanks for any help.
| Re: Is there a way to import tasks? [message #18157 is a reply to message #17220] |
Fri, 09 May 2003 06:19  |
Originally posted by: genadyb.inter.net.il
Andrew McCullough wrote:
> Peter,
> Try the tasks-export plugin here:
> http://sourceforge.net/projects/lunar-eclipse
The plugin should work well with Eclipse 2.0. However, I didn't give
much attention to this plugin lately, so if you have a particular
problem with it, just email me directly.
Genady
> As a shameless plug, you might want to switch over to Insectivore to keep
> your tasks:
> http://www.zclipse.org/projects/insectivore/
> -Andrew
> "Peter Chen" <pchen3@jhmi.edu> wrote in message
> news:b9bun1$s8f$1@rogue.oti.com...
>>Jari Kujansuu wrote:
>>Thanks for the reply.
>>Unfortunately, all my tasks were not added using the TODO tag. I simply
>>went to the "edit" menu
>>and chose to add a new task.
>>Any ideas on how to recover those tasks?
>>>Peter Chen wrote:
>>>>Hey All,
>>>In 2.1 there were some tags you put in java file in comments and then
>>>they were converted to tasks. I use WSAD so haven't been able to get
>>>that far yet, but I have seen my friend use put TODO: in his java files
>>>and they become tasks. So if you use 2.1 you should have this ability
>>>already.
>>>Also there was some team task plugin in
>>>http://eclipse-plugins.2y.net/eclipse/index.jsp
>>>Don't know how it works.
>>> Jari Kujansuu
>>> HUT / INIT
>>> +358 9 451 5679
FUDForum. Page generated in 0.04446 seconds
