Home » Language IDEs » Java Development Tools (JDT) » Invoking eclipse
Invoking eclipse [message #176517] Sun, 05 September 2004 17:38 Go to next message
Originally posted by: manshu.mammmmm.cm
I have an application from which i have to invoke Eclipse and Eclipse also
should be focused on the file say a java file i pass in as argument while
invoking Eclipse.
Is it possible? i did not find any command line argument that Eclipse
takes to open the file. Or if you know an open source application which
does that let me know.
Manshu
Re: Invoking eclipse [message #176841 is a reply to message #176517] Wed, 08 September 2004 10:25 Go to previous message
Here is an idea how you can do it.
In Eclipse you will devolp plugin that implments the early startup
extension.
This plugin extension should do two things:
1. Read from file C:/All/file_name.txt the file name to open.
2. Open editor with this file.
Your application that wants to invoke eclipse will:
1. write the file name to open C:/All/file_name.txt
2. invoke eclipse
Now , when eclipse invoked, it will read file name fromC:/All/file_name.txt
and then open editor for it.
I have another version to idea, I am not sure it will work.
When you invoke eclipse from command line use
eclipse.exe vmargs -DmyFileName="Your file name to open"
Then in the early startup extension try to read 'myFileName' property from
JRE.
Asaf
"manshu" <manshu@mammmmm.cm> wrote in message
news:chg10e$v0m$1@eclipse.org...
> Hello,
> invoking Eclipse.
> Thanks
> Manshu
Previous Topic:Eclipse 3.0 strange shorcuts on Linux
Next Topic:3.1 enum bug
Current Time: Sun Aug 31 23:39:54 EDT 2025
Powered by FUDForum. Page generated in 0.45275 seconds
