Home » Archived » BIRT » Export report to pdf fails
Export report to pdf fails [message #176386] Tue, 11 July 2006 03:11 Go to next message
Originally posted by: test.suncrusher.de
I'm trying to export a report directly to PDF. If no data source is needed - only text - my code is working. With diagram and table I get this error:
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: org/eclipse/emf/common/util/AbstractEnumerator
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:368)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.birt.chart.reportitem.ChartReportItemImpl.<clinit >(ChartReportItemImpl.java:78)
at org.eclipse.birt.chart.reportitem.ChartReportItemFactoryImpl .newReportItem(ChartReportItemFactoryImpl.java:47)
at org.eclipse.birt.report.model.extension.PeerExtensibilityPro vider.initializeReportItem(PeerExtensibilityProvider.java:38 4)
at org.eclipse.birt.report.model.elements.ExtendedItem.initiali zeReportItem(ExtendedItem.java:293)
at org.eclipse.birt.report.model.api.validators.ExtensionValida tor.doValidate(ExtensionValidator.java:95)
at org.eclipse.birt.report.model.api.validators.ExtensionValida tor.validate(ExtensionValidator.java:76)
at org.eclipse.birt.report.model.validators.ValidationNode.perf orm(ValidationNode.java:133)
at org.eclipse.birt.report.model.validators.ValidationExecutor. perform(ValidationExecutor.java:76)
at org.eclipse.birt.report.model.core.DesignElement.validateWit hContents(DesignElement.java:2237)
at org.eclipse.birt.report.model.core.DesignElement.validateWit hContents(DesignElement.java:2246)
at org.eclipse.birt.report.model.core.Module.semanticCheck(Modu le.java:1333)
at org.eclipse.birt.report.model.parser.ModuleParserHandler.end Document(ModuleParserHandler.java:237)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.endEntity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.end Entity(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.loa d(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.ski pSpaces(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$TrailingMiscDispatcher.dispatch(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:89)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:171)
at org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:135)
at org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:208)
at org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:173)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:133)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:102)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:218)
at org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:109)
at TimeTest.createPDF(TimeTest.java:49)
at TimeTest.access$0(TimeTest.java:33)
at TimeTest$1.actionPerformed(TimeTest.java:102)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unk nown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknow n Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
This is my code:
EngineConfig config = new EngineConfig();
config.setEngineHome("C:\\birt-runtime\\ReportEngine");
config.setLogConfig("C:/eclipse/workspace/BIRT_TimeTest/reports ", Level.ALL);
ReportEngine engine = new ReportEngine(config);
try {
// Open a report design - use design to modify design, retrieve
// embedded images etc.
IReportRunnable design = engine.openReportDesign(" C:/eclipse/workspace/BIRT_TimeTest/reports/Timetest_mysql.rp tdesign ");
// Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
// Set Render context to handle url and image locataions
PDFRenderContext renderContext = new PDFRenderContext();
//renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put(EngineConstants.APPCONTEXT_PDF_RENDER_CONTEXT , renderContext);
task.setAppContext(contextMap);
// Set rendering options - such as file or stream output,
// output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
// options.setOutputStream(System.out);
options.setOutputFileName(" C:\\eclipse\\workspace\\BIRT_TimeTest\\reports\\Timetest_mys ql.pdf ");
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
engine.destroy();
} catch (EngineException e1) {
// Ignore
When executing
I receive the error.
Please anybody help me.
Tobias
_____________________________
Tobias Schnupp
mail@suncrusher.de
Germany
Re: Export report to pdf fails [message #176396 is a reply to message #176386] Tue, 11 July 2006 03:19 Go to previous messageGo to next message
The class is not in your classpath.
Extend your classpath with: common.jar or
org.eclipse.emf.common_2.2.0.v200606051102.jar (in Birt 2.1)
exquisitus schrieb:
> this error:
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> Source)
> This is my code:
> Level.ALL);
> try {
> renderContext);
> task.run();
> engine.destroy();
> // Ignore
> When executing
> Thanks
> Tobias
> Tobias Schnupp
> mail@suncrusher.de
> Germany
Re: Export report to pdf fails [message #176412 is a reply to message #176396] Tue, 11 July 2006 03:50 Go to previous message
Originally posted by: mail.suncrusher.de
--------------070308010308070709030906
Thanks a lot :-)
I feel a little bit stupid for not seeing this by my self ;-)
> exquisitus schrieb:
>> this error:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> This is my code:
>> Level.ALL);
>> try {
>> retrieve
>> report
>> renderContext);
>> task.run();
>> engine.destroy();
>> // Ignore
>> When executing
>> Thanks
>> Tobias
>> Tobias Schnupp
>> mail@suncrusher.de
>> Germany
Content-Type: text/x-vcard; charset=utf-8;
name="mail.vcf"
Content-Disposition: attachment;
filename="mail.vcf"
begin:vcard
fn:Tobias SChnupp
n:SChnupp;Tobias
email;internet:mail@suncrusher.de
x-mozilla-html:TRUE
version:2.1
end:vcard
--------------070308010308070709030906--
Previous Topic:Problem to view the report
Next Topic:Error while running a report throuhg java application
Current Time: Wed Nov 12 20:14:31 EST 2025
Powered by FUDForum. Page generated in 0.03730 seconds
