| prevent child figures from capturing mouse [message #176322] | Fri, 08 April 2005 20:41  |  |
| Eclipse User  |  |  |  |  | Originally posted by: christian.sell.netcologne.de
 I have a figure which itself holds a container figure with several
 labels as children. This is similar to the UML and schema editor examples.
 Now I would like mouse drag events to always go to the outermost
 enclosing figure, instead of to the label figures. I removed the layout
 policy and thus got rid of the selection and drag feedback, but if I
 click on a label, the outermost figure still loses focus, and I cannot
 drag the figure.
 I hope I am somewhat clear. This has kept me searching for a while, and
 its late..
 thanks,
 christian
| Re: prevent child figures from capturing mouse [message #176646 is a reply to message #176411] | Mon, 11 April 2005 11:21   |  |
| Eclipse User  |  |  |  |  | Originally posted by: none.us.ibm.com
 Or, if you want them selectable but not draggable, you would have to create
 a custom DragEditPartsTracker which swaps out the source editpart as soon as
 handleDragStarted occurs.
 "Pratik Shah" <ppshah@us.ibm.com> wrote in message
 news:d3bjh5$19b$1@news.eclipse.org...
 > The EditParts corresponding to the inner figures should over
 > isSelectable()
 > and return false.
 > "Christian Sell" <christian.sell@netcologne.de> wrote in message
 > news:d378jr$gki$1@news.eclipse.org...
 >> Hello,
 >> examples.
 >> drag the figure.
 >> its late..
 >> thanks,
 >> christian
| Re: prevent child figures from capturing mouse [message #177026 is a reply to message #176646] | Tue, 12 April 2005 14:31   |  |
 thanks for the tip. In fact, I would prefer to have the child parts
 (database column parts inside a table part) selectable, but have the
 drag apply to the table as a whole. I tried to do as you advised,
 returning a custom DragEditPartsTracker from the getDragTracker method
 of the inner part. The Tracker had the following method overridden:
 protected boolean handleDragStarted() {
 setSourceEditPart(outerPart);
 return super.handleDragStarted();
 However, this did not change anything. The columns are selectable (I
 have a custom SelectionEditPolicy installed for the
 EditPolicy.SELECTION_FEEDBACK_ROLE), but the drag operation does not do
 anything.
 thanks,
 christian
 >>isSelectable()
 >>and return false.
 >>>Hello,
 >>>examples.
 >>>drag the figure.
 >>>its late..
 >>>thanks,
 >>>christian
| Re: prevent child figures from capturing mouse [message #177104 is a reply to message #177026] | Tue, 12 April 2005 15:30  |  |
 Perhaps the source editpart has already been read and copied into the
 Request, and setting it has no effect because the refresh request method
 doesn't expect that parametere to change.
 news:d3h4gj$83f$1@news.eclipse.org...
 > (database column parts inside a table part) selectable, but have the drag
 > apply to the table as a whole. I tried to do as you advised, returning a
 > custom DragEditPartsTracker from the getDragTracker method of the inner
 > However, this did not change anything. The columns are selectable (I have
 > anything.
FUDForum. Page generated in 0.04270 seconds
