Home » Language IDEs » Java Development Tools (JDT) » Java Editor frustrations
Java Editor frustrations [message #176318] Wed, 01 September 2004 18:41 Go to next message
Not sure if this is the right forum - a bit confused by all the different
newsgroups!
Anyway, just wondering if there any plans to provide the following in the
Java Editor:
- dragging highlighted areas
- highlight line with single click
If not, could someone point me in the right direction to customizing
things myself?
cheers,
David
Re: Java Editor frustrations [message #176460 is a reply to message #176318] Fri, 03 September 2004 05:56 Go to previous message
Originally posted by: daniel.megert.gmx.net
David Hay wrote:
>Hi,
>newsgroups!
>Java Editor:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=11624
Window > Preferences > Java > Editor, check "Show line numbers".
You can then click on the line number to select the line. Same works for
the text editor.
Dani
>things myself?
>cheers,
>David
Previous Topic:Templates: modifying ${type_declaration}
Next Topic:Synchronizing Java outline view while typing in the Java editor
Current Time: Thu Jul 31 03:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.04721 seconds
