Home » Language IDEs » ServerTools (WTP) » <import feature="org.eclipse.wst" version="1.5" match="equivalent"/
<import feature="org.eclipse.wst" version="1.5" match="equivalent"/ [message #176220] Thu, 03 August 2006 08:16 Go to next message
<import feature="org.eclipse.wst" version="1.5" match="equivalent"/>
Should this match:
1.5
1.5.0
1.5.0.vANYTHING
1.5.1
1.5.1.vANYTHING
1.5.2
1.5.2.vANYTHING
1.5.9999999
1.5.9999999.vANYTHING
But not:
1
1.4
1.6
2
2.0
At this moment this doesn't work like this. The ATF plugins correctly
(IMHO) set <import feature="org.eclipse.wst" version="1.5"
match="equivalent"/> but it does not match for
org.eclipse.wst_1.5.0.v200606092300-boSnpRZVq78N2Sm from this weeks WTP
I-build in update manager.
Question two, with the addition of the ".0" in "1.5.0" :
<import feature="org.eclipse.wst" version="1.5.0" match="equivalent"/>
Should this match:
1.5.0
1.5.0.vANYTHING
But not:
1
1.4
1.5
1.5.1
1.5.1.vANYTHING
1.5.2
1.5.2.vANYTHING
1.5.9999999
1.6
2.0
Re: <import feature="org.eclipse.wst" version="1.5" match="equivalent&qu [message #176244 is a reply to message #176220] Thu, 03 August 2006 14:45 Go to previous messageGo to next message
Hi Darryl,
Thanks for reporting this issue. Have you opened a bug? If not, care to
open one against Web Tools->releng.
Lawrence
Re: <import feature="org.eclipse.wst" version="1.5" match="equivalent&qu [message #176279 is a reply to message #176244] Thu, 03 August 2006 15:52 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152782
Another related question, why do you bump the version of the I-build
drivers into the next minor release. For example you are already using
1.5.1.v200601010000 but 1.5.1 has not been released yet.
Using 1.5.0.v200601010000 with a higher date is more natural to
understand, that being "a successive build based on 1.5.0 but not yet
1.5.1".
From a which is older/newer standpoint the current method obviously
works fine with the date in it. Maybe this is just a caveat of your
release method chosen but goes a little against the norm.
It would also be really dandy to have pretty names for releases, so when
you spin the build one last time after tagging a release the generated
files gets pretty names when the CVS tag conforms to a release version:
plugins/org.eclipse.wst_1.5.0.v200606092300-RELEASE
Darryl
Previous Topic:Version number problems with last weeks Integration build
Next Topic:getFinalPerspectiveID
Current Time: Mon Jul 21 21:46:46 EDT 2025
Powered by FUDForum. Page generated in 0.24264 seconds
