Home » Archived » BIRT » Errro starting Birt
Errro starting Birt [message #176215] Mon, 10 July 2006 10:11 Go to next message
Hi everybody,
I have this error when i test my class with JUnit :
"org.eclipse.birt.core.exception.BirtException: $NO-RB$ Can't startup the
OSGI framework"
The error occurs on the line --> ReportEngine engine = new
ReportEngine(config);
the code of my class is :
EngineConfig config = new EngineConfig();
config.setEngineHome("C:/Other/Download/birt-runtime-2_0_1/birtruntime/Report
Engine");
ReportEngine engine = new ReportEngine(config);
IReportRunnable design =
engine.openReportDesign("C:/workspace_med/med_client/Diagnoses.rptdesign ");
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("C:/Diagnoses.html");
options.setOutputFormat("HTML");
task.setRenderOption(options);
// run the report and destroy the engine
task.run();
Could you help me ?
thanks a lot
Stéphane
Re: Errro starting Birt [message #176358 is a reply to message #176215] Mon, 10 July 2006 23:13 Go to previous message
The error message you are getting is from BIRT 2.1, but your
runtime appears to be set to 2.0.1. Check to verify that setEngineHome is
correct.
Jason
""St
Previous Topic:Birt with Object Database
Next Topic:Problem to view the report
Current Time: Thu Nov 06 01:10:10 EST 2025
Powered by FUDForum. Page generated in 0.52123 seconds
