Home » Eclipse Projects » GEF » Anchor Problem or Router Problem??
Anchor Problem or Router Problem?? [message #176212] |
Fri, 08 April 2005 11:33  |
Originally posted by: binti.ksu.edu
Hi all,
I am writing an editor that draws sequence diagrams. What I want is the
connections should be created where the user clicks (atleast the the y
coordinate should be that) and I return this location from my own anchor. I
set the request location in this and return it from there.
The code for my anchor is this-
public MyAnchor(IFigure source, Point location)
super(source);
this.location = location;
public Point getLocation(Point reference)
Rectangle r = getOwner().getBounds().getCopy();
getOwner().translateToAbsolute(r);
int off = r.width / 2;
Point p = null;
if(location == null)
p = new Point(r.x + r.width/2, reference.y);
else
p = new Point(r.x + r.width/2, location.y);
return p;
So when I have created the connection, I assume getSourceConnectionAnchor()
and getTargetConnectionAnchor() have been called and the location is set
with the request location, but it still is null here and it returns the
refernce point. Therefore, the connection all start and end from on center
to another (i.e. reference point's y coordinate).
BUT WHEN I CLOSE THE DIAGRAM AND RE OPEN IT, THE CONNECTIONS LOOK FINE.
This is the code for my NodeEditPart -
public ConnectionAnchor getSourceConnectionAnchor(ConnectionEditPart
connectionEditPart)
MyConnectionPart connectionPart = (MyConnectionPart)connectionEditPart;
MyConnection connection= (ActionFlow)connectionPart.getModel();
return new MyAnchor(getFigure(), connection.getLocation());
public ConnectionAnchor getSourceConnectionAnchor(Request request)
CreateConnectionRequest req = (CreateConnectionRequest) request;
return new MyAnchor(getFigure(), req.getLocation());
And I have saved the request location with the connection Model. These
methods are similar for Target as well.
Can someone please explain what is going wrong?
Thanks in Advance,
Binti.
Re: Anchor Problem or Router Problem?? [message #176295 is a reply to message #176212] |
Fri, 08 April 2005 17:41   |
If the location is not set in the model, obviously the problem's with the
model, and not GEF. My guess is that you're setting the connection's source
and target (which cause it to refresh) before its location. In your
connection creation command, if you set the connection's location before its
source or target, I think it would solve your problem.
BTW, for the sake of performance, you should add a setLocation() method on
your anchor class, and then you can have one anchor per EditPart. All the
get*Anchor() methods should then return this same anchor (with the location
updated, of course).
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d368hn$672$1@news.eclipse.org...
> Hi all,
I
> super(source);
> Point p = null;
> else
> return p;
> connectionEditPart)
> Thanks in Advance,
> Binti.
Re: Anchor Problem or Router Problem?? [message #176591 is a reply to message #176295] |
Sun, 10 April 2005 22:30  |
Hey this worked too. Gr8.
Thanks a lot for your help.
Binti.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d36u2s$4qo$1@news.eclipse.org...
> source
> its
> location
>> Hi all,
> I
>> super(source);
>> Point p = null;
>> else
>> return p;
>> center
>> connectionEditPart)
>> Thanks in Advance,
>> Binti.
Current Time: Sun Jul 13 11:20:10 EDT 2025
Powered by FUDForum. Page generated in 0.27427 seconds
