CDT breaks Web Tools Editors [message #175925] |
Fri, 01 September 2006 21:00  |
Hello all,
The current *developement* line of CDT (either 3.1.1 or 4.0.0) causes a SWT bug and thus breaks
the Structured Text editors of the Web Tools, i.e. the HTML, XML, JavaScript and CSS editors.
!MESSAGE Cannot initialize Drop
!STACK 0
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:247)
at org.eclipse.swt.dnd.DND.error(DND.java:208)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:153)
org.eclipse.ui.texteditor.AbstractTextEditor.initializeDragA ndDrop(AbstractTextEditor.java:2485)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2565)
This Exception appears whenever you try to create/open some of this Editor windows.
The Bug Report is here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=152904
"so why can't you use the stable CDT"...?
There is a rather serious problem: The current stable doesn't handle *.C files correctly in
C++ projects as C++ source. This completely defeats the search feature (F3 and ctr-F3), which
is absolutely vital in larger projects. So this problem should be considered high priority!
See the following Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=132201
Is it possible to
- either backport this fix to the current stable
- or get the dev-line to coexist with the Web Tools?
thanks,
Hermann Vosseler
FUDForum. Page generated in 0.09887 seconds
