Home » Eclipse Projects » GEF » Saving as an XML document
Saving as an XML document [message #175878] Wed, 06 April 2005 15:04 Go to next message
Originally posted by: jdelgad.correo.ugr.es
Hi everyone,
I would like to modify the doSave method in order to save the diagram
as an xml document. How can I do this?
Thank you
--Jose
Re: Saving as an XML document [message #175888 is a reply to message #175878] Wed, 06 April 2005 15:18 Go to previous messageGo to next message
Jose,
There are many ways to do this - and you should choose a solution depending
on the complexity of your generation requirements.
To get you started however, you can use JDom.
Build up the DOM in your model - using classes like org.jdom.Element
The Element class will allow you to add attributes and child Elements.
Use XMLOutputter#outputString on the root element of your Tree to get the
XML string, which you can save to a file.
More complex solutions could involve using XSTL or maybe Velocity and
templates for XML generation from your model, not really necessary if the
persistant information is not too complex.
Hope this helps,
Brian.
"Jose" <jdelgad@correo.ugr.es> wrote in message
news:0cd2adc6f17901bd7a0c5412b63ab472$1@www.eclipse.org...
> Hi everyone,
> I would like to modify the doSave method in order to save the diagram as
> Thank you
> --Jose
Re: Saving as an XML document [message #176172 is a reply to message #175888] Fri, 08 April 2005 08:42 Go to previous messageGo to next message
Originally posted by: gary.frederick.jsoft.com
Howdy Brian and all,
I'm interested in this also.
You suggested using JDom. I looked over some of the ways to save an XML
document (including JDom) and picked JAXP 1.3. I'm using it because it
comes with J2SE 5.0 and includes the recent XML and XSLT stuff from
Apache. My work uses XSLT to transform the XML.
Did I choose poorly?
Gary
Brian Fernandes wrote:
> Jose,
> Hope this helps,
> Brian.
>>Hi everyone,
>>Thank you
>> --Jose
Re: Saving as an XML document [message #176262 is a reply to message #176172] Fri, 08 April 2005 14:48 Go to previous messageGo to next message
Gary,
You can't really compare JDOM and JAXP :)
I think this artcle explains it rather nicely (rather dated, but still
mostly valid)
http://www-106.ibm.com/developerworks/xml/library/x-jaxp/
Hope this helps,
Brian.
"Gary Frederick" <gary.frederick@jsoft.com> wrote in message
news:d35uh3$mk3$1@news.eclipse.org...
> Gary
>> Jose,
>> depending on the complexity of your generation requirements.
>> Hope this helps,
>> Brian.
>>>Hi everyone,
>>>Thank you
>>> --Jose
Re: Saving as an XML document [message #176375 is a reply to message #176262] Sat, 09 April 2005 14:43 Go to previous messageGo to next message
I always use XStream for turning arbitrary Java objects into XML, when
the XML does not have to be very human readable. I find it an excellent
solution - far superior to XMLEncoder in the java library. You might
find it worth a look.
Benedict
> Gary,
> mostly valid)
> Hope this helps,
> Brian.
Re: Saving as an XML document [message #185439 is a reply to message #175878] Sat, 25 June 2005 02:46 Go to previous message
hi,
you can do this in the doSave() Methode very simple by using the standard
XML APIs.
Here is s short example:
import java.io.ByteArrayOutputStream;
import org.eclipse.core.resources.IFile;
import javax.xml.parsers.*;
import org.w3c.dom.*;
import javax.xml.transform.*;
import javax.xml.transform.stream.*;
import javax.xml.transform.dom.*;
public void doSave(IProgressMonitor monitor) {
try {
ByteArrayOutputStream out = new ByteArrayOutputStream();
XMLModelParser.saveModel(out);
// create XML DOM Tree
DocumentBuilderFactory domFactory =
DocumentBuilderFactory.newInstance();
DocumentBuilder domBuilder = domFactory.newDocumentBuilder();
Document doc = domBuilder.newDocument();
// Insert the root element node
Element element = doc.createElement("root");
doc.appendChild(element);
// Insert a comment in front of the element node
Comment comment = doc.createComment("a comment");
doc.insertBefore(comment, element);
// Add a text node to the element
element.appendChild(doc.createTextNode("D"));
// Add a text node to the beginning of the element
element.insertBefore(doc.createTextNode("A"),
element.getFirstChild());
// Add a text node before the last child of the element
element.insertBefore(doc.createTextNode("C"),
element.getLastChild());
// Add another element after the first child of the root element
Element element2 = doc.createElement("item");
element.insertBefore(element2,
element.getFirstChild().getNextSibling());
// Add a text node in front of the new item element
element2.getParentNode().insertBefore(doc.createTextNode("B "),
element2);
// Prepare the DOM document for writing
Source source = new DOMSource(doc);
Result result = new StreamResult(out);
// Write the DOM document to the outputstream
Transformer transformer =
TransformerFactory.newInstance().newTransformer();
transformer.transform(source, result);
// save outputstream to IFile....
IFile file = ((IFileEditorInput)getEditorInput()).getFile();
file.setContents(new ByteArrayInputStream(out.toByteArray()),
true, false, monitor);
out.close();
} catch (Exception e) {
e.printStackTrace();
Ralph
"Jose" <jdelgad@correo.ugr.es> schrieb im Newsbeitrag
> Hi everyone,
> Thank you
> --Jose
Previous Topic:GEFrc3,eclipse RC3:draw2d can not get the correct result?
Next Topic:MultiPageEditor tabs + DirectEdit
Current Time: Wed Jul 23 03:59:08 EDT 2025
Powered by FUDForum. Page generated in 0.10038 seconds
